תאור
DSL-2750U/NRU/C - a universal 3G/ADSL/Ethernet-marshrutizator with Wi-Fi and built-in switch. The router lets you connect to the Internet via 3G GSM with 3G USB-modema1, 2. In addition, the device provides a high-speed Internet access technology like ADSL, and technology Ethernet.
The router is equipped with ADSL-port for connecting to the ADSL-line and 4 Ethernet-ports for connecting workstations. With this DSL-2750U/NRU/C is an economical solution to create a wired network and eliminates the need to install a separate switch. In addition, any Ethernet-port devices can be used to connect to a dedicated Ethernet-line.
Also, the router has a USB-port for the USB-modem, printer, or USB-drive. DSL-2750U/NRU/C equipped with wireless 802.11n * standard interface and is compatible with 802.11b standard wireless devices and g as well.
The Router provides many functions for the wireless interface. The device supports several security standards (WEP, WPA/WPA2), filter plug-in device MAC-address, and allows the use of technology to WPS.
DSL-2750U/NRU/C router provides firewall. Enhanced security features allow you to minimize the effects of hackers and prevent intrusion into your network and access to undesirable Web sites for users on your LAN.
To manage and configure DSL-2750U/NRU/C used a simple and convenient built-in web-based interface.
1. USB-modem is not included. D-Link is not guaranteed compatibility with all USB-modems. See Supported USB-modem in the user guide on page 108.
* Maximum wireless speed is limited to 200 Mbps.
מאפיינים כללים
Interfaces
• ADSL: 1 port with RJ-11
• LAN: 4 ports 10/100BASE-TX Ethernet with RJ-45 connector with auto MDI / MDIX cross
• WLAN: built-in wireless interface standard 802.11b/g/n,
• USB: USB 2.0 Port Type A
Wireless Network
• Standard IEEE 802.11n *, compatible with current standard IEEE 802.11b / g
• Support for guest wireless network
• WEP-encryption
• WPA/WPA2 encryption technology with the mechanisms of TKIP, AES and TKIP + AES
• Access to a wireless network based on the MAC-address
• PIN and PBC methods WPS function
• Advanced Settings
ADSL standards
• ADSL: multi-mode, ANSI T1.413 Issue 2, ITU-T G.992.1 (G.dmt) Annex A, ITU-T G.992.2 (G.lite) Annex A, ITU-T G.994.1 (G . hs)
• ADSL2: ITU-T G.992.3 (G.dmt.bis) Annex A / L / M, ITU-T G.992.4 (G.lite.bis) Annex A
• ADSL2 +: ITU-T G.992.5 Annex A / L / M
Types of WAN-connection
• 3G
• ADSL
- PPPoA
- PPPoE
- IPoE
- IPoA
- Bridge
• Ethernet
- Static IP
- DHCP
- PPPoE
Frequency band
From 2.4 GHz to 2.484 GHz
Wireless Speed *
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, 54 Mbit / s
• IEEE 802.11n
20 MHz: 130, 117, 104, 78, 52, 39, 26, 13 Mbit / s
40 MHz: 270, 243, 216, 162, 108, 81, 54, 27 Mbit / s
Transmitter output power
• IEEE 802.11n: 13.5 ~ 16.5 dBm
• IEEE 802.11g: 13.5 ~ 16.5 dBm
• IEEE 802.11b: 16.5 ~ 18.5 dBm
Minutes of ATM / PPP
• Encapsulation of Ethernet in bridge and router
• Multiplexing-based VC / LLC
• ATM Forum UNI3.1/4.0 PVC (up to 8 PVC)
• ATM Adaptation Layer Type 5 (AAL5)
• The principles and functions of OAM ITU-T I.610, including F4/F5 loopback
• ATM QoS
• PPP over ATM (RFC 2,364),
• PPP over Ethernet (PPPoE),
• Support for Keep-alive for PPP-protocol
Network Protocols and Features
• Static IP-routing
• The mechanism of NAT
• DHCP-server/klient/relay
• DNS relay
• Dynamic DNS (DDNS)
• UPnP
• VLAN support
• IGMP proxy
Firewall and Access Control
• NAT firewall
• Monitor status of network connections (SPI)
• Filtering by MAC-addresses from the time of day and day of the week
• URL-filter
• Packet filtering (IP / ICMP / TCP / UDP)
• Virtual Servers
• Prevent DoS-attacks
• Intrusion detection and logging
• Technology to protect DMZ
• Supports Port Triggering
QoS
• Grouping interfaces
• 3 priority queues
USB-modem
• Enable / disable PIN-code verification
• Changing the PIN-code
Configuring and Managing
• Web-based configuration and management in two languages (Russian and English)
• Update the router's internal software via web-interface
• Save and load configuration
• Support for remote logging
• SNMP-agent
• Automatic synchronization of system time from NTP-server
