DSL-2500U/BRU/DEOL EOS
מודם-נתב ADSL2 משולב עם יציאת רשת אחת במהירות 10/100Mbps ותמיכה ב-QOS
תאור
2-IN-1 DEVICE
The D-Link ADSL2/2+ Modem / Router (DSL-2500U) is a 2-in-1 device that combines the function of a DSL modem and 1-port 10/100 Ethernet router. The DSL-2500U supports the latest ADSL2/2+ standards to provide higher performance (up to 24Mbps* downstream and 3.5Mbps* upstream) and longer reach from your Internet Service Provider’s (ISP) Digital Subscriber Line Access Multiplexer (DSLAM). You can also create a wired network to share your high-speed Internet connection, documents, photos, music, videos, printers, and Network Attached Storage (NAS).
ACCESS HIGH-SPEED INTERNET
Unlike a dial-up Internet service, a DSL Internet connection is always on so that you do not have to wait to access the Web. Setting up the DSL-2500U is simple since it automatically detects your DSL settings to quickly establish a connection to the Internet. With support for TR-067, compatibility with your ISP’s infrastructure is ensured. This device also supports TR-069, which automatically updates the firmware and other settings when they become available from your ISP.
ADVANCED NETWORKING
The DSL-2500U includes a built-in QoS engine that helps prioritize Internet traffic to enable smooth Internet phone calls (VoIP) and lag-free online gaming. In addition, this device includes Dual Active Firewalls (SPI and NAT) to help protect your network from potential attacks from across the Internet.
Whether it is for a home user who wants to share high-speed Internet access or for a small office that needs Internet access for conducting essential business activities, the DSL-2500U is the ideal all-in-one broadband and wired networking solution.
WHAT THIS PRODUCT DOES
The DSL-2500U combines the function of a high-speed DSL modem and router. With automatic scanning and detection of your DSL settings, the DSL-2500U quickly sets up your Internet connection. Easily create a wired network and share a high-speed Internet connection while allowing access to shared files, music, photos, and printers with multiple computers.
GREATER COMPATIBILITY
This DSL-2500U is TR-067 compliant, ensuring that it will work with your Internet Service Provider’s (ISP) infrastructure. It is also TR-069 compliant, which automatically updates the firmware and other settings when they become available from your ISP.
* ADSL speeds may vary depending on your individual contract with or services offered by your Internet Service Provider (ISP) and the distance of the modem from the ISP’s DSLAM.
מאפיינים כללים
Technical Specifications
Data Rates*
Downstream: Up to 24Mbps
Upstream: Up to 3.5Mbps
Compliance
TR-067 Interop Performance
TR-069 Compliant with ACS
ADSL Standards
Multi-mode
Full-rate ANSI T1.413 Issue 2
ITU-T G.992.1 (G.dmt) Annex A/C/I
ITU-T G.992.2 (G.lite) Annex A/C
ITU-T G.994.1 (G.hs)
ADSL2 Standards
ITU-T G.992.3 (G.dmt.bis) Annex A/J/K/L/M
ITU-T G.992.4 (G.lite.bis) Annex A
ADSL2+ Standards
ITU-T G.992.5 Annex A/L/M
ATM/PPP Protocols
ATM Forum UNI3.1/4.0 PVC - Up to 8 PVCs
PPP over ATM
PPP over Ethernet
Network Protocols and Features
Ethernet to ADSL Self-Learning Transparent Bridging
Internet Control Message Protocol (ICMP)
IP Static Routing
Routing Information Protocol (RIP, RIPv2)
Network Address Translation (NAT)
Virtual Server, Port Forwarding
NAT ALGs: MSN Messenger, FTP, CUSEEME, H323_Q931 (Netmeeting etc.), H323_RAS, ICQ, etc.
Dynamic Host Configuration Protocol (DHCP)
DNS Relay, DDNS
IGMP Proxy
Simple Network Time Protocol (SNTP)
Firewall
Built-in NAT
MAC Filtering
Packet Filtering
Stateful Packet Inspection (SPI)
Denial of Service Prevention (DoS)
DMZ
VPN
Multiple IPSec/PPTP/L2TP Pass-through
QoS
Port-based Priority
802.1p (0~7) Priority
Configuration and Management
Web-based GUI Configuration
ADSL/ADSL2/ADSL2+ Manual Selection and Auto Fallback
Auto VPI/VCI Detection
Configuration Backup and Restore
Ports
ADSL Port (RJ-11)
1 10/100 Ethernet Port (RJ-45)
LEDs
Power
Status
DSL
LAN
Internet
Temperature
Operating: 32°F to 104°F (0°C to 40°C)
Storage: -4°F to 149°F (-20°C to 65°C)
Humidity
5% to 95% Non-condensing
Certifications
FCC Class B
CE
RoHS
CSA
Dimensions
Item (WxDxH): 7.6” x 5.9” x 1.3”
Packaging (WxDxH): 10.8” x 8.2” x 2.7”
Weight
Item: 0.7 lbs
Packaging: 2.1 lbs
Warranty
2-Year Limited
Minimum System Requirements
Subscription with DSL Internet Service Provider
Computer with a Network Interface Card
Package Contents
ADSL2/2+ Modem with 4-Port Router
Telephone Cable (RJ-11)
Ethernet Cable (RJ-45)
Power Adapter
Quick Installation Guide
CD-ROM*** with:
Installation Wizard
Product Documentation
Special Offers
תקנים
הורדות
איורים
DSL-2500U/BRU/DD4
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
