DSL-2600U/BRU/CEOL EOS
תאור
3 IN-1 DEVICE
The D-Link ADSL2/2+ Modem with Wireless Router (DSL-2600U) is a 3-in-1 device that combines the function of a high-speed DSL modem, wireless G access point, and 1-port Ethernet router. The DSL-2600U supports the latest ADSL2/2+ standards to provide higher performance (up to 24Mbps* downstream and 3.5Mbps* upstream) and longer reach from your Internet Service Provider’s (ISP) Digital Subscriber Line Access Multiplexer (DSLAM).
ACCESS HIGH-SPEED INTERNET
Unlike a dial-up Internet service, a DSL Internet connection is always on so that you do not have to wait to access the Web. Setting up the DSL-2600U is simple since it automatically detects your DSL settings to quickly establish a connection to the Internet. With support for TR-067, compatibility with your Internet Service Provider’s (ISP) infrastructure is ensured. This device also supports TR-069, which automatically updates the firmware and other settings when they become available from your ISP.
CONNECT NETWORKING DEVICES – WIRED OR WIRELESS
With the DSL-2600U, you can create a wireless network to connect 802.11g/802.11b devices as well as a wired network to connect 10/100 Ethernet device. Share your high-speed DSL Internet connection, photos, music, videos, printers, and Network Attached Storage (NAS) with multiple users. The DSL-2600U includes a built-in QoS engine that helps prioritize Internet traffic to enable smooth Internet phone calls (VoIP) and lag-free online gaming. In addition, this device includes Dual Active Firewalls (SPI and NAT) to help protect your network from potential attacks from across the Internet. To prevent unauthorized wireless access into your network, the DSL-2600U supports the latest encryption including WEP, WPA™, and WPA2™.
Whether it is for a home user who wants to share high-speed Internet access or for a small office that needs Internet access for conducting essential business activities, the DSL-2600U is the ideal all-in-one broadband and wireless networking solution.
GREATER COMPATIBILITY
This D-Link ADSL2/2+ Modem with Wireless Router is TR-067 compliant, ensuring that it will work with your Internet Service Provider’s (ISP) network infrastructure. It is also TR-069 compliant, which automatically updates the firmware and other settings when they become available from your ISP.
* ADSL speeds may vary depending on your individual contract with or services offered by your Internet Service Provider (ISP) and the distance of the modem from the ISP’s DSLAM
מאפיינים כללים
Technical Specifications
Data Rates*
Compliance
ADSL Standards
ADSL2 Standards
ADSL2+ Standards
ATM/PPP Protocols
Network Protocols and Features
Firewall
VPN
QoS
Wireless
Configuration and Management
Ports
LEDs
Temperature
Humidity
Certifications
Dimensions
Weight
Warranty
Minimum System Requirements
Package Contents
