DSL-2600U/BRU/CEOL EOS
מודם-נתב ADSL2 אלחוטי בתקן g עם תמיכה ב-QOS
תאור
3 IN-1 DEVICE
The D-Link ADSL2/2+ Modem with Wireless Router (DSL-2600U) is a 3-in-1 device that combines the function of a high-speed DSL modem, wireless G access point, and 1-port Ethernet router. The DSL-2600U supports the latest ADSL2/2+ standards to provide higher performance (up to 24Mbps* downstream and 3.5Mbps* upstream) and longer reach from your Internet Service Provider’s (ISP) Digital Subscriber Line Access Multiplexer (DSLAM).
ACCESS HIGH-SPEED INTERNET
Unlike a dial-up Internet service, a DSL Internet connection is always on so that you do not have to wait to access the Web. Setting up the DSL-2600U is simple since it automatically detects your DSL settings to quickly establish a connection to the Internet. With support for TR-067, compatibility with your Internet Service Provider’s (ISP) infrastructure is ensured. This device also supports TR-069, which automatically updates the firmware and other settings when they become available from your ISP.
CONNECT NETWORKING DEVICES – WIRED OR WIRELESS
With the DSL-2600U, you can create a wireless network to connect 802.11g/802.11b devices as well as a wired network to connect 10/100 Ethernet device. Share your high-speed DSL Internet connection, photos, music, videos, printers, and Network Attached Storage (NAS) with multiple users. The DSL-2600U includes a built-in QoS engine that helps prioritize Internet traffic to enable smooth Internet phone calls (VoIP) and lag-free online gaming. In addition, this device includes Dual Active Firewalls (SPI and NAT) to help protect your network from potential attacks from across the Internet. To prevent unauthorized wireless access into your network, the DSL-2600U supports the latest encryption including WEP, WPA™, and WPA2™.
Whether it is for a home user who wants to share high-speed Internet access or for a small office that needs Internet access for conducting essential business activities, the DSL-2600U is the ideal all-in-one broadband and wireless networking solution.
GREATER COMPATIBILITY
This D-Link ADSL2/2+ Modem with Wireless Router is TR-067 compliant, ensuring that it will work with your Internet Service Provider’s (ISP) network infrastructure. It is also TR-069 compliant, which automatically updates the firmware and other settings when they become available from your ISP.
* ADSL speeds may vary depending on your individual contract with or services offered by your Internet Service Provider (ISP) and the distance of the modem from the ISP’s DSLAM
מאפיינים כללים
Technical Specifications
Data Rates*
Downstream: Up to 24Mbps
Upstream: Up to 3.5Mbps
Compliance
TR-067 Interop Performance
TR-069 Compliant with ACS
ADSL Standards
Multi-mode
Full-rate ANSI T1.413 Issue 2
ITU-T G.992.1 (G.dmt) Annex A/C/I
ITU-T G.992.2 (G.lite) Annex A/C
ITU-T G.994.1 (G.hs)
ADSL2 Standards
ITU-T G.992.3 (G.dmt.bis) Annex A/J/K/L/M
ITU-T G.992.4 (G.lite.bis) Annex A
ADSL2+ Standards
ITU-T G.992.5 Annex A/L/M
ATM/PPP Protocols
ATM Forum UNI3.1/4.0 PVC - Up to 8 PVCs
PPP over ATM
PPP over Ethernet
Network Protocols and Features
Ethernet to ADSL Self-Learning Transparent Bridging
Internet Control Message Protocol (ICMP)
IP Static Routing
Routing Information Protocol (RIP, RIPv2)
Network Address Translation (NAT)
Virtual Server, Port Forwarding
NAT ALGs: MSN Messenger, FTP, CUSEEME, H323_Q931 (Netmeeting etc.), H323_RAS, ICQ, etc.
Dynamic Host Configuration Protocol (DHCP)
DNS Relay, DDNS
IGMP Proxy
Simple Network Time Protocol (SNTP)
Firewall
Built-in NAT
MAC Filtering
Packet Filtering
Stateful Packet Inspection (SPI)
Denial of Service Prevention (DoS)
DMZ
VPN
Multiple IPSec/PPTP/L2TP Pass-through
QoS
Port-based Priority
802.1p (0~7) Priority
Wireless
64/128-bit WEP
Multi-SSID
WPA™-PSK
WPA2™-PSK/Mixed Mode
WDS
802.1x RADIUS
EAP
802.11e WLAN QoS
Configuration and Management
Web-based GUI Configuration
ADSL/ADSL2/ADSL2+ Manual Selection and Auto Fallback
Auto VPI/VCI Detection
Configuration Backup and Restore
Ports
ADSL Port (RJ-11)
1 10/100 Ethernet Port (RJ-45)
LEDs
Power
Status
DSL
WLAN
LAN
Internet
Temperature
Operating: 32°F to 104°F (0°C to 40°C)
Storage: -4°F to 149°F (-20°C to 65°C)
Humidity
5% to 95% Non-condensing
Certifications
FCC Class B
CE
RoHS
CSA
Dimensions
Item (WxDxH): 7.7” x 5.8” x 1.3”
Packaging (WxDxH): 10.8” x 8.2” x 2.7”
Weight
Item: 0.7 lbs
Packaging: 2.4 lbs
Warranty
2-Year Limited**
Minimum System Requirements
Subscription with DSL Internet Service Provider
Computer with a Network Interface Card
Package Contents
CAT5 Ethernet Cable (RJ-45)
Telephone Cable (RJ-11)
Power Adapter
CD-ROM*** with:
Installation Wizard
Product Documentation
תקנים
הורדות
איורים
DSL-2600U/BRU/C/C
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
