DSL-2540U/BRU/DEOL EOS
תאור
2-IN-1 DEVICE
The D-Link ADSL2/2+ Modem with 4-Port Ethernet Router (DSL-2540U) is a 2-in-1 device that combines the function of a DSL modem and 4-port 10/100 Ethernet router. The DSL-2540U supports the latest ADSL2/2+ standards to provide higher performance (up to 24Mbps* downstream and 3.5Mbps* upstream) and longer reach from your Internet Service Provider’s (ISP) Digital Subscriber Line Access Multiplexer (DSLAM). You can also create a wired network to share your high-speed Internet connection, documents, photos, music, videos, printers, and Network Attached Storage (NAS).
ACCESS HIGH-SPEED INTERNET
Unlike a dial-up Internet service, a DSL Internet connection is always on so that you do not have to wait to access the Web. Setting up the DSL-2540U is simple since it automatically detects your DSL settings to quickly establish a connection to the Internet. With support for TR-067, compatibility with your ISP’s infrastructure is ensured. This device also supports TR-069, which automatically updates the firmware and other settings when they become available from your ISP.
ADVANCED NETWORKING
The DSL-2540U includes a built-in QoS engine that helps prioritize Internet traffic to enable smooth Internet phone calls (VoIP) and lag-free online gaming. In addition, this device includes Dual Active Firewalls (SPI and NAT) to help protect your network from potential attacks from across the Internet. With a built-in 4-port 10/100 Ethernet router, up to four network-ready computers or devices can simultaneously be connected to the DSL-2540U.
Whether it is for a home user who wants to share high-speed Internet access or for a small office that needs Internet access for conducting essential business activities, the DSL-2540U ADSL2/2+ Modem with 4-Port Ethernet Router (DSL-2540U) is the ideal all-in-one broadband and wired networking solution.
WHAT THIS PRODUCT DOES
The D-Link ADSL2/2+ Modem with 4-Port Ethernet Router (DSL-2540U) combines the function of a high-speed DSL modem and 4-port router. With automatic scanning and detection of your DSL settings, the DSL-2540U quickly sets up your Internet connection. Easily create a wired network and share a high-speed Internet connection while allowing access to shared files, music, photos, and printers with multiple computers.
GREATER COMPATIBILITY
This D-Link ADSL2/2+ Modem with 4-Port Ethernet Router (DSL-2540U) is TR-067 compliant, ensuring that it will work with your Internet Service Provider’s (ISP) infrastructure. It is also TR-069 compliant, which automatically updates the firmware and other settings when they become available from your ISP.
* ADSL speeds may vary depending on your individual contract with or services offered by your Internet Service Provider (ISP) and the distance of the modem from the ISP’s DSLAM.
מאפיינים כללים
Technical Specifications | |||||||||||||||||||||||
Data Rates* |
Compliance |
ADSL Standards |
ADSL2 Standards |
ADSL2+ Standards |
ATM/PPP Protocols |
Network Protocols and Features |
Firewall |
VPN |
QoS |
Configuration and Management |
Ports |
LEDs |
Temperature |
Humidity |
Certifications |
Dimensions |
Weight |
Warranty |
Minimum System Requirements |
Package Contents |
* ADSL speeds may vary depending on your individual contract with or services offered by your Internet Service Provider (ISP) and the distance of the modem from the ISP's DSLAM.
