DIR-100/FEEOL EOS
תאור
High performance
Broadband Router D-Link DIR-100 is designed for the group of users share a broadband Internet connection through a DSL or cable modem. Simple to install and operate, this router is ideal for novice users creating their first network at home and in small offices.
Quality of Service (QoS)
DIR-100 transmits and receives prioritized VoIP and online traffic to / from the Internet, allowing a group of users a reliable network connection with no traffic delays. QoS support provides broadband access for applications such as Internet telephony, multimedia and games on the Internet.
The high level of network security
The DIR-100 is equipped with a firewall to protect the computers on the network from DOS attacks and virus attacks. With packet filtering device performs access control based on ports and MAC / IP-address source / destination. With the port forwarding the router can be configured to allow separate FTP, and game servers to share the same Internet-visible IP-address, and at the same time, servers and workstations stay protected from hackers. Users can set your home or office Web-site using the settings of any of the LAN ports built to work as a port DMZ. The Parental Control feature allows parents and network administrators to filter out unwanted URL-address Web-sites, block domains and control the timing of the Internet via a schedule.
מאפיינים כללים
WAN interface
• 1 port Small Form-factor Pluggable (SFP) optical connector for 10/100Mbps
• Support for DSL or cable modem connection
• Supports "Always-on" (bridged) and PPPoE for PPTP-connection on demand
LAN interfaces
• 4-port 10/100 BASE-TX Ethernet
• Supports automatic MDI / MDIX cross
• flow control support 802.3x (full duplex) and the method of back pressure (half-duplex)
Support for VPN
• PPTP pass-through
• IPSec pass-through
• L2TP pass-through
Internet gateway functions
• DHCP-server (for automatic assignment of IP-addresses)
User access control
• MAC-address filtering
• Filtering of IP-addresses
• Scheduling
Firewall
• NAT (Network Address Translation) with VPN pass-through
• SPI (Stateful Packet Inspection)
Quality of service
• Transmit / Receive prioritized VoIP-traffic and streaming media
• Multicast stream IGMP (Internet Group Management Protocol)
Configuring and Managing
• Quick Setup Wizard
• Remote management via Telnet
• Web-interface using Internet Explorer v.6, Netscape Navigator v.7 or other Java-enabled browsers
• Dynamic Domain Name System (DDNS)
• Compliance Technologies Universal Plug and Play (UPnP)
• Support for Network Time Protocol (NTP)
Software update
• HTTP (Web-browser)
Diagnostic Lights
• Power / Status
• SFP (Link / Activity)
• LAN ports 1, 2, 3, 4 (Link / Activity)
