DWR-921EOL EOS
נתב אלחוטי עם תמיכה ב 4G LTE
היכן לקנות
תאור
Wireless router with support for 4G LTE DWR-921 allows users to get mobile broadband access to the Internet anywhere. After the connection is established, users can transfer files, streaming media data and send SMS-messages. Simply insert the USIM-card and organize public access to Internet connection 3G / 4G via a secure wireless network, or using any of the four ports Ethernet 10/100 Mbit / s.
High-speed mobile connection
DWR-921 provides high-speed mobile connection 3G / 4G at a rate of receiving data up to 100 Mbit / s and a data rate up to 50 Mbit / s, which enables you to view Web-pages, streaming video and music over the Internet to your computer or mobile device.
Secure wired and wireless connections
DWR-921 is equipped with double firewall (SPI and NAT) to prevent potential attacks from across the Internet. Encryption WPA / WPA2 protects the wireless network that allows you to organize securely share the connection 3G / 4G, without fear that the network will have access to unauthorized users.
Easy to set up and use
Wireless router with support for 4G LTE DWR-921 can be quickly and easily installed almost anywhere. This unit is ideal for use when you need to quickly set up a wireless network in areas where access is not available. DWR-921 can be installed even in buses, trains or boats, allowing passengers to check e-mail or chat online while traveling.
מאפיינים כללים
Device Interfaces
• 4-port LAN 10/100 Mbit / s
• 1 port WAN (with RJ-45 connector)
• 2 detachable antennas 3G / 4G
Baud rate data
• Up to 150 Mbit / s in 802.11n mode
• 6/9/11/12/18/24/36/48/54 Mbit / s in 802.11g
• 1/2 / 5.5 / 11 Mbit / s in 802.11b
• Data transfer rate LTE: up to 50 Mbit / s
• Downstream data rate LTE: up to 100 Mbit / s
Standards
• 802.11g / b, compatible with 802.11n
• 802.3
• 802.3u
Frequency band UMTS / HSDPA / HSUPA2
• 900/2100 MHz
• Power Class 3
Bandwidth LTE
• 900/1800/2600/800 MHz
Wireless Security
• 64/128-bit encryption WEP (Wired Equivalent Privacy)
• WPA and WPA2 (Wi-Fi Protected Access)
Firewall
VPN
• L2TP / PPTP / IPSec VPN Pass-through
נתונים פיזיים
Indicator
• WAN
• LAN
• WLAN
• 4G
• 3G
• SMS
• Signal
Dimensions
• 190 x 111,5 x 23,5 mm
Weight
• 500 g
Temperature
• Working from 0 to 40 C
Humidity
Certificates
• CE
• Wi-Fi Certified
תקנים
הורדות
איורים
DWR-921
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
