DIR-822EOL EOS
תאור
The DIR-822 AC1200 Wi-Fi Router is a powerful wireless networking solution designed for Small Office/Home Office (SOHO) environments. By combining high-speed 802.11ac Wi-Fi specification with dual-band technology and Fast Ethernet ports, the DIR-822 provides a seamless networking experience with a high degree of convenience and flexibility for SOHOs. The DIR-822’s SOHO-class advanced security features keep data safe from unwanted network intruders. This together with the increased range and reliability of Wireless AC technology, helps provide a safe and secure network for devices farther into your home or office.
High-Speed Wired and Wireless Connectivity
The DIR-822 AC1200 Wi-Fi Router upgrades your network to the latest high-speed wireless technology to bring you lightning-fast Wi-Fi speeds of up to 1200 Mbps so you can meet the ever-greater demand for multimedia applications. Enjoy streaming media, Internet phone calls, online gaming, and content-rich web surfing throughout your home or office. In addition, 10/100 Fast Ethernet ports give you solid, dependable wired performance for devices such as NAS, media centers and gaming consoles. The built-in easy-to-use Quality of Service (QoS) engine allows you to prioritize important traffic to ensure that your favorite applications are receiving optimal bandwidth.
Dual Band Wireless for Seamless Performance
The DIR-822 AC1200 Wi-Fi Router features dual-band wireless, allowing you to operate two concurrent, high-speed Wi-Fi bands for ultimate wireless performance. Surf the web or make important Internet phone calls on the 2.4 GHz band, while simultaneously streaming digital media on the 5 GHz band. What’s more, each band can operate as a separate Wi-Fi network, giving you the ability to customize your network according to your connectivity needs. You can even configure a guest zone to give visitors Internet access without compromising the safety of your SOHO network.
Easy to Set Up, Easy to Secure
Sharing your Internet connection doesn’t have to be a complicated process - just open a web browser to access D-Link’s modern, user-friendly graphical web interface. The setup wizard’s easy to use step-by-step instructions will have your network up and running in minutes. Implement WPA/WPA2 wireless security in minutes with the wireless network setup wizard, or use Wi-Fi Protected Setup (WPS), which establishes a secure connection to new devices without the need to enter settings or create passwords. In addition, the built-in firewall protects against malicious attacks from the Internet, and access control features allow you to restrict access to your network giving you greater control over network users
מאפיינים כללים
Interfaces
• WAN port 10 / 100BASE-TX
• 4-port LAN 10 / 100BASE-TX
Indicators
• Power
• Internet
• WPS
• Wireless network
• 4 LAN LEDs
Button
• POWER button to turn on / off
• RESET button to return to the factory settings
• WPS button to establish a secure wireless connection and enable / disable the wireless network
Antenna
• Four non-removable external antenna with a gain of 3 dBi
MIMO scheme
• 2 x 2
Power connector
• Power connector (DC)
WAN connection types
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IP / Dynamic IP
• Static IPv6 / IPv6 Dynamic
• PPPoE + Static IP / Dynamic IP
• PPTP / L2TP + Static IP
• PPTP / L2TP + Dynamic IP
Networking features
• Supports IEEE 802.1X standard for connecting to the Internet
• DHCP-server / relay
• DHCPv6-Server (Stateful / Stateless), IPv6 prefix delegation
• DNS relay
• Support Class AAAA records DNSv6
• Dynamic DNS
• Static IP-Routing
• Static IPv6-routing
• IGMP Proxy
• RIP
• UPnP IGD support
• VLAN Support
• Support ping function from the external network (WAN ping respond)
• Support for the SIP ALG mechanism
• RTSP support
• Setting speed, duplex mode and flow control (flow control) in the auto-negotiation mode / Manual setting of speed and duplex mode for each Ethernet-port
Firewall Security
• Stateful Inspection (SPI)
• IP-filter
• IPv6-filter
• MAC-Filter
• URL-filter
• DMZ-zone
• protection function ARP- and DDoS-attacks
• Virtual Servers
VPN
• IPSec / PPTP / L2TP / PPPoE pass-through
• IPSec-Tunnels
Control
• Local and remote access for TELNET / WEB (HTTP / HTTPS) settings
• Web-based interface for configuration and management of multiple languages
• Notification of problems with connection and automatic redirection to the settings
• Update the router through the web-based interface
• Automatic notification of the availability of a new software version
• Saving and loading configurations
• Support of remote logging
• Automatic synchronisation of system time with a NTP-server and manually configure the date and time
• ping utility
• Traceroute utility
• TR-069 Client
Standards
• IEEE 802.11a / n / ac
• IEEE 802.11b / g / n
Frequency band
• 2400 ~ 2483.5 MHz
• 5150 ~ 5350 MHz
Wireless Security
• WEP
• WPA / WPA2 (Personal / Enterprise)
• MAC filter
• WPS (PBC / PIN)
Additional functions
• «Client" mode
• WMM (Wi-Fi QoS)
• Information on the connected Wi-Fi-clients
• Advanced settings
• Intelligent distribution of Wi-Fi-customers
Wireless Speed
• IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11b: 1, 2, 5.5 and 11 Mbit / s
• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48 and 54 Mbit / s
• IEEE 802.11n (2,4 GHz / 5 GHz): 6.5 to 300 Mbit / s (MCS0 to MCS15)
• IEEE 802.11ac (5 GHz) of 6.5 to 867 Mbit / s (MCS0 to MSC9)
