חיפוש מהיר
תכונות המוצר:
4G LTE USB Router
מאפיינים כללים:
Device Interfaces
• USB 2.0
• microSD card slot (up to 32 GB)
• SIM slot (6-pin)
Radio Frequency Bands
• LTE-FDD B5 / B7 / B28
• (850 / 2600 / 700 MHz)
• Power Class 3 (+23 dBm)
• LTE-FDD B3 / B7 / B20 (available upon request)
• (1800 / 2600 / 800 MHz)
• UMTS / HSDPA / HSUPA / HSPA+ B1 / B8 (available upon request)
• (900 / 2100 MHz)
• UMTS / HSDPA / HSUPA / HSPA+ B1 / B5
• (850 / 2100 MHz)
• Power Class 3 (+24 dBm) Quadband GSM / GPRS / EDGE
• (850 / 900 / 1800 / 1900 MHz)
• Power Class 4 (850 / 900 MHz)
• Power Class 1 (1800 / 1900 MHz)
Cellular Access
• LTE: 3GPP Rel-9 FDD-LTE Cat.4
• Downlink: 150 Mbps
• Uplink: 50 Mbps
• LTE Bandwidth
• 1.4, 3, 5, 10, 15, 20 MHz
• DC-HSPA+:
• Downlink: 42 Mbps
• Uplink: 11 Mbps
Wi-Fi Access Point
• 802.11n (75 Mbps)
• 802.11g (54 Mbps)
• 802.11b (11 Mbps)
Wireless Security
• WPA2-PSK Auto (TKIP / AES)
• WPA-PSK Auto (TKIP / AES)
• WEP (64 / 128-bit)
• MAC filter
Connection Manager Software Requirements
• Windows 8 / 7 / Vista / XP, Mac OS X 10.5 or higher, or Ubuntu Linux 10.04 or higher**
• 128 MB RAM or greater
• 50 MB available disk space
Antenna
• Internal LTE main antenna
• Internal LTE diversity antenna
• Internal Wi-Fi antenna
LED Indicators
• LTE
• Green (blinking): Connected to LTE network
• Blue (blinking): Connected to 3G network
• Purple (blinking): Connected to 2G network
• Red (blinking): No service/device error
• Wi-Fi
• Green (solid): Connected
Plug and Play
• Built-in drivers and software; no CD-ROM required
Connection Software Features
• Web GUI
• Phonebook
• SMS
• Wizard
• APN
• Traffic display and statistics
Wi-Fi Features
• Auto channel selection
• Wi-Fi Protected Setup (WPS)
• Up to 10 connected clients
Advanced Features
• 3G fallback
• Supports IPv6
Physical Parameters
Dimensions
• 113 x 37 x 11.5 mm
Weight
• 40.5 grams
Temperature
• Operating: 0 to 45 В°C
Certifications
• WHQL
* Data rates are theoretical. Data transfer rate depends on network capacity and signal strength.
** Linux support for driver only.
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
