חיפוש מהיר
תכונות המוצר:
מערכת ניהול גישת משתמשים לרשתות (Multi-service gateway) ל- SOHO ו- SMB
מאפיינים כללים:
Functions provided
• Placement of up to 250 user accounts in an internal database
• Supports up to 50 or 80 (for the audit DSA-3110/E/B) concurrent online users
• Access Protocol: PPTP
• Support for https secure connection
• Authentication and authorization based on the ID / Password
• Support for RADIUS authentication mechanism and internal
     Can be used by only one of these mechanisms
• Access to the WEB-interface management
• Remote access to the command line interface via SSH
• Setting up the CLI using the console port RS-232
• Supports NAT, Port Forwarding, DMZ (CLI)
• Static IP, DHCP-client on the interfaces
• MPPE encryption support with 40-bit key
Hardware platform
Processor
• IHP-425 Intel 266 MHz or Intel IXP-425 533
• MHz (for audit DSA-3110/E/B)
Memory
• 64 MB of SDRAM
Ports of the device
• 7 10/100Mbps Fast Ethernet
• 4 independently configurable interfaces
• Console Port: RS-232 (the default options 115 200, n, 8, 1, no flow control)
Indicators
• Power
• Status (Status)
• 7 indicators Fast Ethernet ports
נתונים פיזיים
Power
• Through external power adapter
Input voltage
• 5V/3A DC
Size
• 239 x 156 x 30 mm
Weight
• 1.2 kg
Housing material
• steel
Operating temperature
• 0 ° to 40 ° C
Storage temperature
• -20 ° to 70 ° C
Humidity
• From 5% to 95% without condensation
Electromagnetic compatibility
• CE
• FCC Class A
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
