חיפוש מהיר
תכונות המוצר:
מערכת ניהול גישת משתמשים לרשתות אלחוטיות (Hotspot-service gateway)
מאפיינים כללים:
• Up to 250 user accounts in an internal database
• Up to 50 or 80 (for the audit DSA-3110/E/B hotspot edition) concurrent online users
• Access protocol: http
• Support for https secure connection
• Authentication and authorization based on the ID / Password
• Support for internal authentication mechanism
• Support for the editor checks (when used in conjunction with thermal printer checks DSA-3100P, UNS-SP1 or Citizen CBM-910II-40RF230-A)
• Access to the WEB-interface management
• Remote access to the command line interface via SSH
• Supports NAT, Port Forwarding, DMZ (CLI)
• Static IP, DHCP-client on the interfaces
Hardware platform
• Processor
• IHP-425 Intel 266 MHz or Intel IXP-425 533 MHz (for audit DSA-3110/E/B hotspot edition)
Memory
• 64 MB of SDRAM
Ports of the device
• 7 10/100Mbps Fast Ethernet
• 4 independently configurable interface (can be used as LAN, WAN, port delivery statistics)
Indicators
• Power (Power)
• Status (Status)
• 7 indicators Fast Ethernet ports
נתונים פיזיים
Power
• Through external power adapter
Input voltage
• 5V/3A DC
Size
• 239 x 156 x 30 mm
Weight
• 1.2 kg
Housing Material
• steel
Operating temperature
• 0 ° to 40 ° C
Storage temperature
• -20 ° to 70 ° C
Humidity
• From 5% to 95% without condensation
Electromagnetic compatibility
• CE
• FCC Class A
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
