DWA-525EOL EOS
תאור
High-speed
 wireless networking
Connect to a high-speed wireless network with the D-link Wireless N 150
Desktop Adapter and enjoy surfng the web, checking e-mail, and chatting
with family and friends online. The DWA-525 uses Wireless N 150
technology, which offers increased speed and range over the 802.11g/b
standard1 giving you a faster, more reliable wireless connection.
Connect securely to your wireless network
To protect your data and privacy, the Wireless N 150 Desktop Adapter
supports WEP, WPA, and WPA2 encryption for connecting to a secure
wireless network, keeping your network traffc secure.
Compatibilyty assurance
The Wireless N 150 Desktop Adapter provides a high-speed connection to
other Wireless 802.11n devices and is backward compatible with
802.11g/b, ensuring compatibility with a wide range of wireless routers
and networks.
Easy to install & connect
D-Link’s Quick Setup Wizard provides easy setup of your USB adapter so
you can get connected quickly. Wi-Fi Protected Setup (WPS) sets up a
secure wireless connection, so all you have to do is push a button to
automatically create a secure wireless connection to your network, doing
 away with the need for confguring complicated settings.
מאפיינים כללים
		System requirements
		Computer with:
		• Windows 2000 (SP4), XP (SP2), or Vista (32 or 64-bit) or higher
		• CD-rOM drive
		• 20MB hard disk space
		• Available USB port
		Standards
		• IEEE 802.11n
		• IEEE 802.11g
		• IEEE 802.11b
		Frequency range
		• 2.4GHz to 2.4835GHz
		Antenna
		• Detachable 2dBi dipole antenna
		Security
		• 64/128-bit WEP data encryption
		• Wi-Fi Protected Access (WPA/WPA2-PSK, WPA/WPA2-EAP)
		• Wi-Fi Protected Setup (WPS)
		Data rates
		• 802.11n: up to 150 Mbps
		• 802.11g: 6/9/12/18/24/36/48/54 Mbps
		• 802.11b: 1/2/5.5/11 Mbps
		 O.S. Support
		• Windows XP/Vista and Windows 7
		Diagnostic leds
		• Link/Activity
תקנים
הורדות
דרייברים
דרייבר 1.10
הערות הפצה לדרייבר 1.10
דרייבר 2.3.0.0 ללינוקס
הערות הפצה לדרייבר 2.3.0.0 ללינוקס
דפי מידע
דף מידע
מדריכים
מדריך למשתמש
מדריך התקנה מהירה
