DGE-560SXEOL
תאור
		High-performance Gigabit Ethernet network adapter for the bus PCI Express D-Link DGE-560SX allows you to increase network performance with support for PCI Express (PCI-E) and optical connection.
		PCI Express interface
		In full-duplex adapter DGE-560SX supports data rates up to 2 Gbit / s, providing high bandwidth between the adapter and the server. With fault tolerance, reliability and performance, DGE-560SX is the perfect solution for connecting input and output devices to a wide range of storage servers. Having to replace a PCI and PCI-X, architecture PCI Express bus eliminates many of the drawbacks of architectures with parallel PCI buses and PCI-X. Due to fewer contacts and less power consumption, DGE-560SX adapter allows to reduce the power consumption of the entire system.
		Advanced Features
		DGE-560SX supports Jumbo-frames up to 9 KB, and the specification ACPI (Advanced Configuration and Power Management) to enable OSPM (configuration and power management controlled by the operating system). In addition, the adapter supports SNMP-agent management via SNMP.
		VLAN and QoS support
		Network Adapter DGE-560SX supports embedded filtering of tagged Ethernet-VLAN frame in accordance with standard IEEE 802.1Q. This allows the server to operate in a flexible and secure network, established in accordance with the standards. The adapter also supports priority queues, according to the protocol 802.1p, for the transmission of delay-sensitive data (eg, voice and video).
		Fiber optic connection
		Supporting data rates up to 2000 Mbit / s fiber-optic cable in full duplex mode, the adapter DGE-560SX provides enough bandwidth when connecting to the server. Hardware calculation headers and checksums IP-packets offloads the CPU of network nodes, and improve network performance.
מאפיינים כללים
		Network cables and transmission distance
		• 62.5 / 125 micron multimode optical fiber cable (275 m)
		• 50/125 micron multimode fiber optic cable (up to 550 m)
		Networking mode
		• Full Duplex (2000 Mbit / s)
		Data rate
		• 1 Gb / s
		Supported Features
		• Support for Jumbo-frames 9 KB
		• Supports 802.1p QoS priority queues
		• Security VLAN 802.1Q, 64 groups
		• Power management ACPI 2.0
		• SNMP statistics
		• Card Teaming
		• Remote Boot
		Supported Drivers
		• Microsoft Windows 7 32/64-bit
		• Microsoft Windows 8 32/64-bit
		• Microsoft Windows 8.1 32/64-bit
		• Microsoft Windows Vista 32/64-bit
		• Windows Server 2008 R2,2012
		• Windows Server
		• Windows Server 2012 R2
		• Linux Kernel 2.4.x, 2.6.x and 3.x
		• FreeBSD 7.x or higher
		• Novell ODI
