DGE-660TDEOL EOS
כרטיס רשת PCMCIA לנייד
תאור
Main Features
    *      Built-in Gigabit Ethernet Port
    *      Windows XP Compatible
    *      Supports Full-duplex Operation–20/200/2000Mbps*
    *      Compatible with Existing 10/100Mbps Networks
    *      Supports Auto-negotiation
    *      Minimal Power Consumption for Increased Battery Life
    *      Hot Swappable
GIGABIT PERFORMANCE
The D-Link DGE-660TD Gigabit Notebook Adapter equips your notebook computer for lightning fast speeds across your home or office network. Waiting hours for large audio and video file transfers are a thing of the past. The D-Link DGE-660TD gives you the power to bring your network up to the next level. With the DGE-660TD Gigabit Notebook Adapter, you can send and receive data at rates up to 10x faster than a 100Mbps Network*. And with Gigabit technology, you have the power of a full-duplex environment. The DGE-660TD is ideal for transferring large files such as pictures, music, videos, PowerPoint®, Auto-CAD, PhotoShop®, and more.
HIGH PERFORMANCE NETWORKING FEATURES
The D-Link DGE-660TD Gigabit Notebook Adapter is PCMCIA compliant, so compatibility with your network is never a problem. Using your notebook on multiple networks with varying network speeds has never been easier. There is no need to manually configure your card each time you move between your 100Mbps and Gigabit networks. Plus, the DGE-660TD is hot-swappable, so there’s no need to power down your notebook when installing and removing the device. With the included Autorun CD, installation has never been easier. Bring your notebook into the Gigabit generation with D-Link’s DGE-660TD Gigabit Notebook Adapter.
WHAT THIS PRODUCT DOES
Connect to your wired home network by adding a Gigabit Notebook Adapter to your notebook computer. Access shared documents, music, photos, and video from other computers and devices from your network at gigabit speeds. Additionally, access your high-speed Internet connection to check e-mail, surf the Web, and chat with friends and family.
D-LINK WILL HELP YOU
Setting up your D-Link Gigabit Notebook Adapter is easy. Simply insert the included Installation CD into your CD-ROM drive, select “Install Driver”, and your computer is ready to be networked. If you need additional help, visit D-Link’s award-winning Customer Support Web Site for answers to frequently asked questions, product downloads, and easy access to D-Link’s friendly customer support team.
* Speed rate based on IEEE standard. Actual data throughput will vary. Network conditions and environmental notebook factors may lower actual data throughput rate.
מאפיינים כללים
Complies with PCMCIA CardBus
• Support for 32-bit bus
• Auto Negotiation for Speed ​​10/100/1000Mbps
• Supports full duplex 2000Mbit / s Gigabit Ethernet
• Built-in RAM buffer for transmission 8K/priema 64K
• One shielded RJ-45 connector
• Supports cabling UTP / STP
• Low power consumption
• The possibility of a "hot" replacement
• Indicators for the convenience of diagnosis
• Cable diagnostic function
• Drivers for Win98 SE, 2000, ME, XP
Standards
• IEEE 802.3 10BASE-T Ethernet
• IEEE 802.3u 100BASE-TX Fast Ethernet
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet
• Auto-negotiation of ANSI / IEEE 802.3 NWay
• Specification PCMCIA 2.x
• 32-bit CardBus
Network cables
• 10BASE-T:
• UTP Cat. 3, 4, 5 (100 m max.)
• EIA/TIA-586 100-ohm STP (100 meters max.)
• 100BASE-TX, 1000BASE-T:
• UTP Cat. 5 (100 m max.)
• EIA/TIA-568 100 - ohm STP (100 meters max.)
Protocol
• CSMA / CD
Type of adapter
• PC Card Type II CardBus
Indicators
• Link / Active
• Speed ​​(1000Mbps / s - green, 100Mb / s - yellow)
Full / half duplex
• Full duplex only (1000Mbps / s)
• Full / half duplex (10/100Mbps)
תקנים
הורדות
איורים
DGE-660TD
מראה מקדימה
דף מידע
ראה גם
