חיפוש מהיר
תכונות המוצר:
VOIP Gateway עם 2 יציאות FXS, יציאה 1 10/100BASE-TX
דגם לא מיוצר יותר
תאור:
Internet phone made for home & soho
The D-Link DVG-2102S 2-port VoIP Telephone Adapter (TA) allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over IP network technology with advanced communication features, and is compatible with industry wise phone service. With 2 FXS phone ports, this VoIP TA connects you to an ordinary phone set to let you make Internet phone calls.
Superior voice quality
The DVG-2102S incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference, phone book, speed dialing and hot lines to make it convenient to dial out or answer phone calls.
Complete security
The DVG-2102S supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It also provides various types of DOS protection in an attempt to make computer resources unavailable to its intended users.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
