DPH-400SE/E/F1EOL EOS
טלפון VOIP עם 2 יציאות LAN, תמיכה בשלושה חשבונות SIP נפרדים, תמיכה ב POE
היכן לקנות
תאור
INTERNET PHONE MADE FOR HOME & OFFICE
The DPH-400SE Broadband Internet IP Phone allows you to take advantage of your DSL/cable modem connection to make inexpensive Internet phone calls. It combines the industry’s latest Voice over the IP network (VoIP) technology with advanced communication features, and is compatible with industry-wide phone services. This sleek designed IP phone gives you the advantages of VoIP, while retaining the same look and feel of a traditional desktop telephone.
SUPERIOR VOICE QUALITY
The DPH-400SE IP phone incorporates Quality of Service (QoS) to ensure that voice received through the Internet is the same as or even surpasses that received on the ordinary phone. It supports many useful functions such as call transfer, caller ID display, 3-way conference and speed dialing to make it convenient to dial out or answer phone calls.
SURF INTERNET WHILE MAKING INTERNET PHONE CALLS
The DPH-400SE comes with two Ethernet ports, one to connect to a DSL or cable modem, or to your broadband router. In an office environment equipped, this port can also connect to a PoE switch and obtain power directly from the network, dispensing you of the need to hook the IP phone to an AC power outlet. Once connected and logged onto the Internet, you are ready to make and receive calls. In addition, this IP phone provides another Ethernet port for connection to your PC, so you can talk on the IP telephone while browsing web sites, send e-mail, transfer files and do other network tasks on your PC.
QUALITY OF SERVICE AND SECURITY
The DPH-400SE supports voice VLAN to isolate your voice communication so it cannot be tapped over the network. It provides priority queues to streamline traffic so web browsing and Internet download will not interfere with voice traffic and degrade Internet phone quality.
מאפיינים כללים
ממשק רשת
  • 2 פורטים RJ-45 10/100BASE-TX Ethernet
פרוטוקולים
  • SIP RFC 3261
  • SIP RFC 2327
  • RTP RFC 1889
  • DHCP ו PPPoE
  • STUN, static port mapping
  • SNTP
  • DNS ו DNS SRV
  • TFTP/FTP/HTTP
  • IP/TCP/UDP/ARP/ICMP
אודיו קודקים
  • G.711a/u
  • G.729A/B
  • G.723.1
 QoS
  • זיהוי קול VAD
  • Jitter buffer
  • DTFM
  • Packet Lost Concealment PLC
  • IEEE 802.1p
  • Diffserv (DSCP)/ToS
מקלדת
  • תפריט
  • 3 מקשים לבחירת אפשרויות על המסך
  • 6 מקשים memory
  • 3 מקשים SIP line
  • RLS
  • ספר טלפונים
  • MWI
  • Hold
  • Transfer
  • Mute
  • Speaker
  • 12 מקשים עם מספרים כולל * ו #
  • מקשי ווליום
פונקציות שיחה
  • Call Hold Resume
  • העברת שיחה
  • Call forwarding
  • שיחה ממתינה
  •  דואר קולי
  • שיחה מזוהה
  • רשימה שחורה
  • Limit List
  • קו חם
עידכוני קושחה
  • עידכוני קושחה דרך  FTP/TFTP/HTTP
  • APS auto-provisionningלעידכון קושחה ופרופיל
 CoS
  • תמיכה ב - VLAN ID
  • VLAN Tag
  • L2TP VPN
פונקציות מתקדמות
  • Memo
  • SMS
  • Pre-dial before sending
  • 12 מספרים לחיוג מהיר
  •  זמן שיחה
  • תאריך
  • ספר טלפונים עד 500 רשומות
  • יומן שיחות עד 100 רשומות
  • זיהוי שיחה
  • 3 חשבונות SIP
נתונים פיזיים
משקל
  • 625 גרם
מידות
  • 220X250X85 מ"מ
חשמל
  • 5V - 1A
תקנים
הורדות
איורים
DPH-400SE/E/F1
מראה מקדימה
דף מידע
ראה גם
