חיפוש מהיר
תכונות המוצר:
נתב אלחוטי בתקן 1200AC עם כניסת WAN אופטית, עם תמיכה ב 3G/LTE, עם 2 כניסות FXS, עם כניסה PSTN וכניסת USB
תאור:
Voice connection
VoIP-Router is equipped with two FXS-ports that allow you to connect analog telephones to make calls over the Internet, and one PSTN-port (lifeline) for connection to the local telephone network.
USB-port
The router is equipped with a USB-port for connection of USB-modem with which you can quickly connect to the Internet. In addition, you can connect to USB-port router USB-drive to be used as a network drive, or printer.
Ethernet WAN
Any Ethernet-port devices can be configured to connect to a dedicated Ethernet-line.
Wireless Interface
Using a Wireless Router DVG-N5402G / ACF, you can quickly organize a high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices, virtually anywhere (in the range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz wireless network can be used for a wide range of tasks. A router can act as a base station to connect to a wireless network devices, operating according to the standards 802.11a, 802.11b, 802.11g, 802.11n and 802.11ac (with the speed of the wireless connection to a 1167 Mbit / C1).
The router provides many functions for the wireless interface. The device supports several security standards (WEP, WPA / WPA2), filtering devices to be connected on the MAC-address, and allows the use of the WPS and WMM.
Furthermore, the device is equipped with a button for switching off / on Wi-Fi-network. In case of need, such as leaving your home, you can turn off the router's wireless network at the touch of a button, and the devices connected to the LAN-port router will remain in the network.
Security
Wireless Router DVG-N5402G / ACF has a built-in firewall. Enhanced security functions minimize threats of hacker attacks, prevent unwanted intrusions into your network and access to unwanted websites for users of your LAN.
Easy setup and update
To set up a wireless router DVG-N5402G / ACF using the user-friendly web-interface (available in several languages).
Now you can easily update the firmware - the router itself is validated on the server version of the software update D-Link and notifies the user ready to install it.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
