חיפוש מהיר
תכונות המוצר:
VOIP Station / Trunk Gateway עם 2 יציאות FXO , כ- 6 יציאות FXS, יציאת WAN, כ- 4 יציאות LAN וראוטר מובנה
מאפיינים כללים
מאפיינים כללים:
Device Interfaces
• 6-port FXS c RJ-11
• 2-port FXO with RJ-11
• 1-port 10/100BASE-TX RJ-45 WAN
• 4-port 10/100BASE-TX RJ-45 LAN with Ethernet
Connection type
• DHCP-client
• PPPoE-client
• PPTP
• Cable BigPond (Australia)
Routing
• DHCP-server
• Virtual Server
• DMZ
• Filtering based on port, IP, MAC, URL
• RIP v.1, v.2, Static route
• DDNS: DynDns.org, TZO, 3322.ORG
• NAT Traversal: pass-through NAT, client STUN, UPnP
Phone book
• Server phone book management, up to 200 entries IAD
SIP
• Register port "By Port" "By machine
• Dialing in the standard E.164
• Redundant SIP PROXY (registration)
• SIP PING
• CLIR (Anonymous Caller ID)
• Function hot line / warm line
• Functions of a group call
• Hold, Call Waiting, Call
• Call forwarding: with accompaniment / unaccompanied
• Call forwarding: unconditional, busy, no answer
• 3-way conference
• T.30 fax pass-through
• T.38 fax relay
• Adjustable tone detection Fax
• Out of band DTMF: RFC2833, SIP INFO
Voice Features
• G.711 a / u, G.726 (32K), G.729A, G.723.1
• Adjustable jitter-buffer
• Variable packet size (depending on codec)
• Detection and Noise Reduction
• Echo
• Local phone book enables you to call other VoIP devices without registration
• Speed ​​Dial
• Call filter - accept / reject calls from the IP-address
• ID-generation FXS-Call: DTMF, FSK (Bell core / ETSI)
• Support the FLASH button
Management
• Web-based interface and Telnet, IVR
Indicators
• Power
• Reset
• Alarm
• Run
נתונים פיזיים
Power consumption
• After the AC adapter 100 to 240 VAC, 50/60 Hz
Dimensions
• 302 x 179 x 45 mm
Weight
• 1.2 kg
Operating temperature
• From 0 to 45 C
Storage temperature
• -10 To 55 C
Humidity
• Up to 90% noncondensing
Radiation
• FCC Class B
• CE
Security
• UL
• CUL
• En60950
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה
