DPH-400EDMEOL EOS
פאנל מודולרי - 24 שלוחות לטלפון DPH-400S עם נוריות LED
תאור
 Description:
DPH-400EDM is an extension module for phones DPH-400S and DPH-400SE. Expansion module is equipped with 24 physical keys, two of whom are shift keys (Shift). With the shift key, using the module DPH-400EDM can organize up to 44 additional logical buttons that can be configured for certain functions, but also be used to accelerate or abbreviated dialing. Among the programmable functions such as voice mail, call forwarding feature «Do not disturb» and many others.
מאפיינים כללים
             Specifications:
             Options module expansion
·         24 keys on the display module, of which 2 - selection key register
·         44 logical key indicator
Physical parameters
Power consumption
·         4.62 W (DPH-400S phone or DPH-400SE + DPH-400EDM)
Dimensions
·         50 (D) x 162 (W) x 56 (H) mm
Weight
·         120 g
Operating temperature
·         5o to 40o C
Storage temperature
·         -20o to 65o C
Working humidity
·         From 10% to 90% without condensation
Humidity Storage
·         From 5% to 95% without condensation
תקנים
הורדות
איורים
DPH-400EDM
מראה מקדימה
דף מידע
ראה גם
