DVC-1000EOL EOS
וידאופון i2Eye IP
היכן לקנות
תאור
Works With:
Broadband Cable Modem
DCM-202
2X 4-8mm Varifocal Lens
DVC-20
The D-Link DVC- 1000 i2eyeTM VideoPhone introduces the world of video conferencing over the Internet, to bring you and your family, friends and colleagues together. Since the DVC-1000 i2Eye VideoPhone is a stand-alone device, you do not need a computer to video conference over the Internet.
The previously complicated process of conducting a video conference is simplified with the DVC-1000. Connect a standard telephone and a television to the DVC-1000, plug in a standard Ethernet network cable connected to your broadband Internet connection and you are ready to conduct real-time videoconferencing.
Watch episode on i2eye Broadband Videophones.
Using advanced video compression technology, the DVC-1000 VideoPhone maximizes the image and audio quality within the available bandwidth. The DVC-1000 can send and receive video at up to a full 30 frames per second. It is an ideal solution for consumers and small businesses with high-speed Internet access.
Easy to use set-up wizards guide you step-by-step through the set-up of the DVC-1000 VideoPhone. You can be up and working in minutes. With the DVC-1000 it is easy to make changes to personalize your videoconferencing display.
The remote control that is included with the DVC-1000 allows you to easily answer an incoming videophone call or initiate a new one. The built-in caller ID provides privacy protection. You can know who is calling before you answer.
Be there real-time, anytime. You won’t miss a moment with your friends, family and colleagues with the i2eye DVC-1000 VideoPhone.
מאפיינים כללים
Specifications
Internal Processor
  • ARM-9 ASIC Communication Processor
Standards
  • H.323 (IP communications)
  • H.263 (Video)
  • G.711 (Audio)
  • G.723 (Audio)
Frame Rates
  • 96 Kbps-512 Kbps
  • Up to 30fps
Video
  • CIF (352 x 288 pixels)
  • QCIF (176 x 144)
Audio
  • Telephone Interface
  • Echo Cancellation
  • Voice Only to / from Voice over IP Endpoints
  • Half-duplex Speakerphone
Input/Output
  • Power
  • Audio Out
  • Video Out
  • Ethernet RJ-45
  • External Microphone
Camera
  • Manual Tilt
  • Manual Focus
User Interface
  • Dialing
  • Diagnostics
  • Quality of Service Measurement
  • Manual or Auto Answer
  • Incoming Caller ID
  • Privacy Via Video/Audio Mute and Do Not Disturb Mode
  • Answer with Infrared Remote Control or Telephone
LED Indicators
  • Power
  • Status
  • Video Monitor
  • Ethernet Link &Transmit
Dialing Capabilities
  • Speed Dial List (10 Entries)
  • Dial VideoPhone Number Using Built-in i2eye Directory Service
  • Dialing Using Direct IP Address Entry
Remote Software Update
  • Software Update, Automatic or Manual
Dimensions
  • D=6.08"
  • W=8.07"
  • H=1.50"
Weight
  • 0.398kg
Warranty
  • 1 Year
נתונים פיזיים
תקנים
הורדות
איורים
DVC-1000
מראה מקדימה
דף מידע
ראה גם
