חיפוש מהיר
תכונות המוצר:
נתב VPN התומך בטכנולוגיית Cloud
תאור:
Broadband VPN-Router Cloud D-Link DIR-140L is a device that combines the functions of a router, switch, 10/100 Mbit / s, VPN and Firewall, designed specifically for the market SOHO (Small Office, Home Office), place high demands on performance and safety of the product, which must be made in a compact desktop chassis. As the needs of small businesses in the network services is a key factor in the need to provide a reliable solution for network security. DIR-140L provides a high return on investment through robust security features, flexible configuration and a high degree of protection for networks SOHO.
Customizable user interface
DIR-140L is equipped with an intuitive Web-based user interface that allows the device to easily customize and manage. Management options can be set with administrator privileges or read / write. Using data access control levels, any authorized user can easily configure or access the management interface of the router DIR-140L.
The service mydlink network management
Broadband VPN-router supports Cloud service mydlink Cloud, which allows the user to easily access to the network, regardless of its location. With the PC connected to the Internet or a mobile device with iOS or Android, you can use the view of clients connected to the router, change settings, or block access to the individual clients. Home users can check the most frequently visited Internet sites their children, and for the offices the ability to monitor network activity of workers.
Advanced hardware features
DIR-140L can be connected to a cable or DSL-modem to share high-speed Internet access. Also, the device is equipped with a 4-port 10/100 Mbit / s, which supports full duplex mode, which allows you to connect up to 4 devices with interfaces Ethernet. To extend the wired network, simply add more switches. In addition, using DIR-140L, you can create a virtual private network (VPN) and provide secure remote access to a central network through the Internet for up to 25 users simultaneously.
VPN performance
For optimal VPN configuration, the router DIR-140L is equipped with a built-in VPN-client and the VPN-server, which keeps most of the required policies VPN. In this device, VPN support is implemented in hardware and manage up to 25 profiles VPN. DIR-140L supports the IPSec, PPTP, L2TP and GRE as a server, and allows you to handle the traffic pass-through. Advanced VPN configuration options include encryption, DES, key management IKE / ISAKMP, to desirable Main / Aggressive and authentication support VPN, using a database of 10 internal users.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
