DIR-825/AC/E1AEOL
נתב אלחוטי דואל-בנד בתקן AC-1200 עם 4 יציאות גיגהביט ויציאת USB להתקנים שונים
היכן לקנות
תאור
USB-port
The router is equipped with a USB-port for connecting the USB-modem with which you can quickly connect to the Internet. In addition, you can connect to USB-port router USB-drive, which will be used as a network drive, or printer.
Wireless Interface
Using a wireless router DIR-825, you can quickly organize high-speed wireless network at home or in the office, providing Internet access to computers and mobile devices almost anywhere (in the range of a wireless network). Simultaneous operation in the 2.4 GHz and 5 GHz wireless network can be used for a wide range of tasks. The Router can serve as a base station to connect to a wireless network devices, operating according to the standards 802.11a, 802.11b, 802.11g, 802.11n and 802.11ac draft (with speed wireless connection up to 1167 Mbit / s) 1.
In the router supports multiple functions for the wireless interface. The device supports several security standards (WEP, WPA / WPA2), filtration devices to be connected to MAC-address, and allows you to use the WPS and WMM.
In addition, the device is equipped with a button to disable / enable the Wi-Fi-network. In case of need, such as leaving home, you can turn off the wireless network router at the touch of a button, and the devices connected to the LAN-ports on the router to remain in the network.
Security
Wireless Router DIR-825 is equipped with a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions into your network and access to unwanted websites for users of your LAN.
Easy setup and update
To set up a wireless router DIR-825 uses a simple and user-friendly web-interface (available in several languages).
Now you can easily update the firmware - the router itself is a proven software version on the update server DLink and notifies the user ready to install it.
מאפיינים כללים
Interfaces
• WAN port 10/100 / 1000BASE-TX
• 4-port LAN 10/100 / 1000BASE-TX
• USB 2.0 port
Indicators
• POWER
• STATUS
• WAN
• 4 LAN indicator
• WLAN
Button
• ON / OFF button to power on / off
• RESET button to return to the factory default settings
• WPS button to establish a secure wireless connection and enable / disable the wireless network
Antenna
• Two non-removable external antenna with a gain of 2 dBi for 2.4 GHz and 3 dBi for 5 GHz
Power connector
• Connector for power supply (DC)
WAN connection types
• LTE
• 3G
• PPPoE
• IPv6 PPPoE
• PPPoE Dual Stack
• Static IP / Dynamic IP
• Static IPv6 / IPv6 Dynamic
• PPPoE + Static IP
• PPPoE + Dynamic IP
• PPTP / L2TP + Static IP
• PPTP / L2TP + Dynamic IP
Network Functions
• Supports IEEE 802.1X standard for connecting to the Internet
• DHCP-server / relay
• DHCPv6-server (Stateful / Stateless), IPv6 prefix delegation
• DNS relay
• Support Class AAAA records DNSv6
• Dynamic DNS
• Static IP-routing
• Static IPv6-routing
• IGMP Proxy
• RIP
• Supports UPnP IGD
• VLAN support
• Flow control (flow control)
• Supports ping from the external network (WAN ping respond)
• Support for SIP
• Support for RTSP
Firewall Features
• IP-filters
• IPv6-filters
• MAC-filter
• URL-filter
• DMZ-zone
• The protection ARP- and DDoS-attacks
• Virtual Servers
• Built-in content filtering service Yandeks.DNS
VPN
• IPSec / PPTP / L2TP / PPPoE pass-through
• VPN-tunnels (PPPoE, PPTP, L2TP)
• IPSec-tunnel
Function USB-interface
• USB-modem
   Automatic connection to available type of supported network (4G / 3G / 2G) 2
   Enable / disable PIN-code verification, change PIN-koda3
• USB-drive
   Print Server
   Built-in Samba server
   Built-in FTP-server
   Built-in DLNA-server
   Built-torrent-client Transmission, the possibility of downloading files on USB-drive with him
Management
• Local and remote access to the settings on the TELNET / WEB (HTTP / HTTPS)
• Web-based interface for configuration and management of multiple languages
• Notification of problems with connection and automatic redirection settings
• Update the router through the web-interface
• Automatic notification when a new software version
• Saving and loading configuration
• Support for remote logging
• Automatic synchronization of system time with a NTP-server and manually configure the date and time
• Ping
• Traceroute
• Client TR-069
נתונים פיזיים
• Dimensions 195 x 155 x 35 mm
• Weight 250 g
• Power Output: 12 V DC, 1.5 A
Temperature
• Operating: 0 to 40 ° C
• Storage: -20 to 65 ° C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Supported USB-modems
GSM
• Alcatel X500
• D-Link DWM-152C1
• D-Link DWM-156A6
• D-Link DWM-156A7
• D-Link DWM-156C1
• D-Link DWM-157B1
• D-Link DWM-157B1 (Velcom)
• D-Link DWM-158D1
• Huawei E150
• Huawei E1550
• Huawei E156G
• Huawei E160G
• Huawei E169G
• Huawei E171
• Huawei E173 (Megafon)
• Huawei E220
• Huawei E352 (Megafon)
• Huawei E367 (3G-mode)
• Huawei E392 (3G-mode)
• ZTE MF112
• ZTE MF192
• ZTE MF626
• ZTE MF627
• ZTE MF652
• ZTE MF667
• ZTE MF668
• ZTE MF752
CDMA
• Airplus MCD-650
• Airplus MCD-800
• AnyDATA ADU-300A
• AnyDATA ADU-500A
• AnyDATA ADU-510A
• Huawei EC306
• ZTE AC5710
• ZTE AC5730
LTE
• Huawei E3131
• Huawei E3272
• Huawei E367
• Huawei E392
• Megafon M100-1
• Megafon M100-3
• Megafon M100-4
• Megafon M150-1
• Yota LU-150
• Yota WLTUBA-107
• ZTE MF823
• ZTE MF827
• MTS 824F
תקנים
הורדות
איורים
DIR-825/AC/E1A/G1
מראה מאחורה
מראה מקדימה
מראה מימין
דף מידע
ראה גם
