DP-301P+EOL EOS
שרת מדפסות 10/100Mbps - ממשק Paralel, בגודל pocket size
תאור
D-Link, an industry leader in networking, introduces the DP-301P+ Express EtherNetworkTM Fast Ethernet Print Server. The DP-301P+ is a compact print server that allows you to share your parallel printer on an Ethernet network. Now, everyone on your network can enjoy the benefits of sharing a single printer.
The DP-301P+ is a great alternative to software-based printer sharing. The DP-301P+ eliminates the need to have your printer connected to a host computer. With the DP-301P+, everyone on your network can be sure that their printing jobs go through at any time. Documents also print faster from the DP-301P+ than from software-based printer sharing solutions.
The DP-301P+ is designed to make installation simple. It has a built-in Centronics connector that connects directly to your printer without the hassle of using a printer cable. Its compact size makes placement of the DP-301P+ easy—even in areas with limited space.
The DP-301P+ supports all the major networking protocols such as TCP/IP, NetBEUI, AppleTalk, and EtherTalk. It is compatible with computers running Windows, Macintosh, Linux, and all other TCP/IP compatible operating systems.
The DP-301P+ is easily configured using a Web-browser. With the user-friendly Web-based setup, you can quickly configure your DP-301P+ Print Server from any computer on the network. A PSAdmin configuration program is also included to configure your DP-301P+ for Windows-based systems.
Add the DP-301P+ to your home, school, or small office network for the convenience of a shared network printer.
מאפיינים כללים
Standards
IEEE 802.2
IEEE 802.3
IEEE 802.3u
IEEE 1284
Port
10/100 Mbps Fast Ethernet
Parallel Port with Centronics connector
Data Transfer Rate
10/100Mbps
Transport Protocols
TCP/IP
NetBEUI
AppleTalk/EtherTalk
TCP/IP Protocols Supported
BOOTP
SNMP
Telnet
TFTP
FTP
LPD
RARP
DHCP
Management
SNMP
MIBs
MIB-II (RFC 1213)
Diagnostic LEDs
Power
Link/Activity
LPT
Power Input
External Power Supply
DC 5V, 2.5A
Dimensions
L = 3.54 inches (90mm)
W = 2.2 inches (56mm)
H = 1.02 inches (26mm)
Weight
0.32 lbs (147g)
Operating Temperature
0°C to 50°C
Storage Temperature
-25°C to 55°C
Humidity
5% -95%, non-condensing
Warranty
1 Year
תקנים
הורדות
איורים
DP-301P+
מראה מקדימה
דף מידע
ראה גם
