DP-301UEOL EOS
שרת מדפסות 10/100Mb - ממשק USB
היכן לקנות
תאור
Product Description:
DFE-530TX+
D-Link, an industry leader in networking, delivers a network printing solution with the compact 10/100 Ethernet USB Print Server (DP-301U). With this USB print server, users can print from virtually anywhere on the network to the connected USB printer* using computers with different operating systems.
EASY INSTALLATION
With its high-speed USB 2.0 port, the DP-301U connects to a wide variety of printers and delivers astonishing printing speeds. The set up process is remarkably simple. It can be configured using a web-based setup utility. Alternatively, Windows®-based PCs can also use the included PS Admin program to manage the DP-301U. Its compact size ensures that the USB Print Server can be added to any printing situation without creating additional installation hassles.
PRINT FROM MULTIPLE COMPUTERS
The USB Print Server can alleviate printing problems by simplifying network printing. Sharing a single USB printer eliminates the need to maintain and purchase supplies for multiple printers. Additionally, a dedicated print server removes the need to have a dedicated computer powered on to support the printer.
SUPPORTS MULTIPLE OPERATING SYSTEMS
The DP-301U supports virtually all major network operating systems and protocols. For exceptional network compatibility, clients can communicate with the DP-301U using TCP/IP, NetBEUI, and AppleTalk transport protocols. Regardless of your network setup, the DP-301U is an excellent addition.
The D-Link 10/100 Ethernet USB Print Server (DP-301U) is the ideal network printing solution for the home, office, or school. Simply adding this dedicated print server to your network frees up system resources and simplifies your printing experience.
WHAT THIS PRODUCT DOES
The D-Link® 10/100 Fast Ethernet USB Print Server (DP-301U) allows you to share a USB enabled printer across the network. With the DP-301U, anyone on the network can readily access a shared printer. Additionally, having a print server helps save energy by eliminating the need for a dedicated computer to be powered on all the time to host a shared printer.
SHARING A PRINTER
The DP-301U is compact enough to be placed in areas with limited space and helps alleviate printing problems by simplifying network printing. Sharing a single USB printer eliminates the need to maintain and purchase supplies for multiple printers.easy access to the D-Link friendly customer support team.
מאפיינים כללים
Standards
IEEE 802.2
IEEE 802.3
IEEE 802.3u
USB 2.0/1.1
Device Interface
10/100Mbps Fast Ethernet
USB 2.0 Port
Transport Protocol
TCP/IP
NetBEUI
AppleTalk/EtherTalk
TCP/IP Protocols Supported
BOOTP
SNMP
Telnet
TFTP
FTP
LPD
RARP
DHCP
Management
SNMP
MIBs
MIB-II (RFC 1213)
Diagnostic LEDs
Power
Link/Activity
USB
Power Input
External Power Supply
DC 5V, 2.5A
Dimensions
Item (WxDxH): 3.19” x 3.54” x 1.57”
Weight
0.27 lbs (121g)
Temperature
Operating: 32°F to 122°F (0° to 50°C)
Storage: -13°F to 131°F (-25° to 55°C)
Operating Humidity
5% ~ 95% Maximum (Non-condensing)
Warranty
1 Year Limited*
Minimum System Requirements
Computer with:
Windows Vista®, Windows® XP SP2, Windows 2000 SP4**, or Mac OS® X (v10.2/v10.3)***
Printer with USB Connection
Package Contents
Power Adapter
Quick Installation Guide
CD-ROM**** with:
Installation Wizard
Product Documentation
נתונים פיזיים
תקנים
הורדות
איורים
DP-301U
מראה מקדימה
דף מידע
ראה גם
