DIR-816/ACEOL EOS
Wireless AC750 Dual Band Router with 3G/LTE Support and USB Port
תאור
USB Port
The router is equipped with a USB port for connecting a USB modem, which can be used to establish connection to the Internet. In addition, to the USB port of the router you can connect a USB storage device, which will be used as a network drive, or a printer.
Wireless Interface
Using the DIR-816 device, you are able to quickly create a high-speed wireless network at home or in your office, which lets computers and mobile devices access the Internet virtually anywhere (within the operational range of your wireless network). Simultaneous activity of 2.4GHz band and 5GHz band allows performing a wide range of tasks. The router can operate as a base station for connecting wireless devices of the standards 802.11a, 802.11b, 802.11g, 802.11n, and 802.11ac (at the wireless connection rate up to 733Mbps1).
Secure Wireless Connection
The router supports multiple functions for the wireless interface: several security standards (WEP, WPA/WPA2), MAC address filtering, WPS, WMM.
Support of guest Wi-Fi network allows you to create a separate wireless network with individual security settings. Devices connected to the guest network will be able to access the Internet, but will be isolated from the devices and resources of the router's LAN.
Security
The wireless router DIR-816 includes a built-in firewall. The advanced security functions minimize threats of hacker attacks, prevent unwanted intrusions to your network, and block access to unwanted websites for users of your LAN.
In addition, the router supports IPsec and allows to create secure VPN tunnels.
Built-in Yandex.DNS service protects against malicious and fraudulent web sites and helps to block access to adult content on children's devices.
Easy configuration and update
You can configure the settings of the wireless router DIR-816 via the user-friendly web-based interface (the interface is available in several languages).
The configuration wizard allows you to quickly switch DIR-816 to one of the following modes: router (for connection to a wired or wireless ISP), access point, repeater, or client, and then configure all needed setting for operation in the selected mode in several simple steps.
You can simply update the firmware: the router itself finds approved firmware on D-Link update server and notifies when ready to install it.
1Up to 300Mbps for 2.4GHz and up to 433Mbps for 5GHz.
מאפיינים כללים
				 Hardware
				 Processor
				 • MT7620A (580MHz)
				 RAM
				 • 64MB, DDR2
				 Flash
				 • 16MB, SPI
				 Interfaces
				 • 10/100BASE-TX WAN port
				• 4 10/100BASE-TX LAN ports
				• USB 2.0 port
				 LEDs
				 • POWER
				• 2.4G WLAN
				• 5G WLAN
				• INTERNET
				• WPS
				 Buttons
				 • ON/OFF button to power on/power off
				• WPS/RESET button to set up wireless connection and to restore factory default settings
				 Antenna
				 • Three external non-detachable antennas (5dBi gain)
				 MIMO
				 • 2 x 2 (for 2.4GHz)
				 Power connector
				 • Power input connector (DC)
| Software | |
				 WAN connection types
				 • LTE
				• 3G
				• PPPoE
				• IPv6 PPPoE
				• PPPoE Dual Stack
				• Static IP / Dynamic IP
				• Static IPv6 / Dynamic IPv6
				• PPPoE + Static IP / Dynamic IP
				• PPTP/L2TP + Static IP
				• PPTP/L2TP + Dynamic IP
				 Network functions
				 • Support of IEEE 802.1X for Internet connection
				• DHCP server/relay
				• DHCPv6 server (Stateful/Stateless), IPv6 prefix delegation
				• DNS relay
				• Support of DNSv6 AAAA records
				• Dynamic DNS
				• Static IP routing
				• Static IPv6 routing
				• IGMP Proxy
				• RIP
				• Support of UPnP IGD
				• Support of VLAN
				• WAN ping respond
				• Support of SIP ALG
				• Support of RTSP
				• WAN reservation
				• Autonegotiation of speed, duplex mode, and flow control/Manual speed and duplex mode setup for each Ethernet port
				• Built-in UDPXY application
				• XUPNPD plug-in
				 Firewall functions
				• IP filter
				• IPv6 filter
				• MAC filter
				• URL filter
				• DMZ
				• Prevention of ARP and DDoS attacks
				• Virtual servers
				• Built-in Yandex.DNS web content filtering service
				 VPN
				 • IPSec/PPTP/L2TP/PPPoE pass-through
				• IPSec tunnels
				 USB interface functions
				 • USB modem
				Auto connection to available type of supported network (4G/3G/2G)
				Auto configuration of connection upon plugging in USB modem
				Enabling/disabling PIN code check, changing PIN code1
				• USB storage
				File browser
				Print server
				Access to storage via accounts
				Built-in Samba server
				Built-in FTP server
				Built-in DLNA server
				Built-in Transmission torrent client; uploading/downloading files from/to USB storage
				 Management
				 • Local and remote access to settings through TELNET/WEB (HTTP/HTTPS)
				• Bilingual web-based interface for configuration and management (Russian/English)
				• Support of logging to remote host/connected USB storage
				• Ping function
				• Traceroute utility
				• TR-069 client
				• SNMP agent
				 Wireless Module Parameters
				 Standards
				 • IEEE 802.11a/n/ac
				• IEEE 802.11b/g/n
				 Frequency range
				 • 2400 ~ 2483.5MHz
				• 5150 ~ 5350MHz
				• 5650 ~ 5725MHz
				 Wireless connection security
				 • WEP
				• МАС filter
				• WPS (PBC/PIN)
				 Advanced functions
				 • Support of client mode
				• WMM (Wi-Fi QoS)
				• Information on connected Wi-Fi clients
				• Advanced settings
				• Guest Wi-Fi / support of MBSSID
				• Periodic scan of channels, automatic switch to least loaded channel
				 Wireless connection rate
				 • IEEE 802.11a: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11b: 1, 2, 5.5, and 11Mbps
				• IEEE 802.11g: 6, 9, 12, 18, 24, 36, 48, and 54Mbps
				• IEEE 802.11n (2.4GHz/5GHz): from 6.5 to 300Mbps (from MCS0 to MCS15)
				• IEEE 802.11ac (5GHz): from 6.5 to 433Mbps (from MCS0 to MSC9)
				 Transmitter output power
				 • 802.11a (typical at room temperature 25 °C)
				15dBm at 6, 9, 12, 18, 24, 36, 48, 54Mbps
				• 802.11b (typical at room temperature 25 °C)
				15dBm at 1, 2, 5.5, 11Mbps
				• 802.11g (typical at room temperature 25 °C)
				• 802.11n (typical at room temperature 25 °C)
				2.4GHz, HT20/HT40
				15dBm at MCS0~15
				5GHz, HT20/HT40
				15dBm at MCS0~15
				• 802.11ac (typical at room temperature 25 °C)
				VHT20
				15dBm at MCS0~7
				14.5dBm at MCS8
				VHT40
				15dBm at MCS0~7
				14.5dBm at MCS8~9
				VHT80
				15dBm at MCS0~7
				14.5dBm at MCS8~9
				 Receiver sensitivity
				 • 802.11a (typical at PER < 10% (1000-byte PDUs) at room temperature 25 °C)
				-93dBm at 6Mbps
				-92dBm at 9Mbps
				-91dBm at 12Mbps
				-90dBm at 18Mbps
				-86dBm at 24Mbps
				-84dBm at 36Mbps
				-79dBm at 48Mbps
				-77dBm at 54Mbps
				• 802.11b (typical at PER = 8% (1000-byte PDUs) at room temperature 25 °C)
				-98dBm at 1Mbps
				-95dBm at 2Mbps
				-93dBm at 5.5Mbps
				-90dBm at 11Mbps
				• 802.11g (typical at PER = 10% (1000-byte PDUs) at room temperature 25 °C)
				-91dBm at 6Mbps
				-90dBm at 9Mbps
				-88dBm at 12Mbps
				-86dBm at 18Mbps
				-84dBm at 24Mbps
				-81dBm at 36Mbps
				-76dBm at 48Mbps
				-74dBm at 54Mbps
				• 802.11n (typical at PER = 10% (1000-byte PDUs))
				2.4GHz, HT20
				-90dBm at MCS0
				-89dBm at MCS1
				-87dBm at MCS2
				-84dBm at MCS3
				-81dBm at MCS4
				-77dBm at MCS5
				-75dBm at MCS6
				-74dBm at MCS7
				2.4GHz, HT40
				-88dBm at MCS0
				-86dBm at MCS1
				-84dBm at MCS2
				-81dBm at MCS3
				-77dBm at MCS4
				-74dBm at MCS5
				-72dBm at MCS6
				-70dBm at MCS7
				5GHz, HT20
				-92dBm at MCS0
				-91dBm at MCS1
				-90dBm at MCS2
				-86dBm at MCS3
				-84dBm at MCS4
				-78dBm at MCS5
				-77dBm at MCS6
				-75dBm at MCS7
				5GHz, HT40
				-90dBm at MCS0
				-89dBm at MCS1
				-87dBm at MCS2
				-84dBm at MCS3
				-79dBm at MCS4
				-76dBm at MCS5
				-75dBm at MCS6
				-73dBm at MCS7
				• 802.11ac (typical at PER = 10% (1000-byte PDUs))
				HT20
				-92dBm at MCS0
				-91dBm at MCS1
				-90dBm at MCS2
				-86dBm at MCS3
				-84dBm at MCS4
				-79dBm at MCS5
				-77dBm at MCS6
				-76dBm at MCS7
				-71dBm at MCS8
				HT40
				-90dBm at MCS0
				-89dBm at MCS1
				-87dBm at MCS2
				-84dBm at MCS3
				-81dBm at MCS4
				-76dBm at MCS5
				-74dBm at MCS6
				-73dBm at MCS7
				-68dBm at MCS8
				-66dBm at MCS9
				HT80
				-85dBm at MCS0
				-84dBm at MCS1
				-83dBm at MCS2
				-80dBm at MCS3
				-76dBm at MCS4
				-72dBm at MCS5
				-70dBm at MCS6
				-68dBm at MCS7
				-63dBm at MCS8
				-61dBm at MCS9
				 Modulation schemes
				 • 802.11a: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11g: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11n: BPSK, QPSK, 16QAM, 64QAM with OFDM
				• 802.11ac: BPSK, QPSK, 16QAM, 64QAM, 256QAM with OFDM
				 Physical Parameters
				 Dimensions (L x W x H)
				 • 192 x 108 x 30 mm (7.56 x 4.25 x 1.18 in)
				 Weight
				 • 245 g (0.54 lb)
| Operating Environment | |
				 Power
				 • Output: 12V DC, 1A
				 Temperature
				 • Operating: from 0 to 40 °C
				• Storage: from -20 to 65 °C
				 Humidity
				 • Operating: from 10% to 90% (non-condensing)
				• Storage: from 5% to 95% (non-condensing)
| Delivery Package | |
				 • Router DIR-816
				• Power adapter DC 12V/1A
				• Ethernet cable
				 Supported USB modems2
				 GSM
				 • Alcatel X500
				• D-Link DWM-152C1
				• D-Link DWM-156A6
				• D-Link DWM-156A7
				• D-Link DWM 156A8
				• D-Link DWM-156C1
				• D-Link DWM-157B1
				• D-Link DWM-157B1 (Velcom)
				• D-Link DWM-158D1
				• D-Link DWR-710
				• Huawei E150
				• Huawei E1550
				• Huawei E156G
				• Huawei E160G
				• Huawei E169G
				• Huawei E171
				• Huawei E173 (Megafon)
				• Huawei E220
				• Huawei E3131 (MTS 420S)
				• Huawei E352 (Megafon)
				• Prolink PHS600
				• Prolink PHS901
				• ZTE MF112
				• ZTE MF192
				• ZTE MF626
				• ZTE MF627
				• ZTE MF652
				• ZTE MF667
				• ZTE MF668
				• ZTE MF752
				 LTE
				 • Huawei E3131
				• Huawei E3272
				• Huawei E3351
				• Huawei E3372
				• Huawei E367
				• Huawei E392
				• Megafon M100-1
				• Megafon M100-2
				• Megafon M100-3
				• Megafon M100-4
				• Megafon M150-1
				• Megafon M150-2
				• Quanta 1K6E (Beeline 1K6E)
				• MTS 824F
				• MTS 827F
				• Yota LU-150
				• Yota WLTUBA-107
				• ZTE MF823
				• ZTE MF827
				 Smartphones in USB tethering mode
				 • Some models of Android smartphones
1For GSM USB modems and some models of LTE USB modems.
2The manufacturer does not guarantee proper operation of the router with every modification of the firmware of USB modems.
תקנים
הורדות
DIR-816/AC  Wireless AC750 Dual Band Router with 3G/LTE Support and USB Port
