DPR-1061EOL EOS
שרת מדפסות קווי הכולל 2 יציאות USB + יציאה פרללית
היכן לקנות
תאור
 Share Your Printers And Multifunction Equipment
The DPR-1061 3-Port Print Server provides users with 3 available ports from a single device, and offers print and scan compatibility for those who are using multifunction equipment. This print server allows users to directly send out documents from their PC for fax transmissions. Enjoy sharing your printer and multifunction equipment's printing, faxing, and scanning abilities among the users on your network - all with a single print server.
Simultaneous Operation Of All Devices
Equipped with a powerful CPU, large memory, high speed USB ports and network data transfer, this print server makes your operations fast. Devices attached to the DPR-1061 can print, scan, and fax at the same time, giving this multi-port print server a similar performance to 3 separate single-port print servers at a fraction of the cost.
Access Security And Multiple Os Support
The DPR-1061 provides the necessary security by allowing the administrator to configure user access right to the network printers and equipment. It supports a wide range of network OS including: Windows 95/98/ME/NT 4.0/2000/XP, Apple MacOS with AppleTalk, Linux, Solaris, SCO Unix, IBM AIX and NetWare 5.x native NDS. Enjoy the flexibility and compatibility in major network OS that this print server has to offer.
Remote Printing Support
The DPR-1061 supports the Internet Printing Protocol (IPP), enabling remote users to output files to their office printer even when they are away from the site. HP PJL protocol is also supported for bi-directional network printer communication, providing network administrators with critical information about the network printer. Regardless of where you are, never worry about being unable to print out important files ever again with this print server’s convenient functions.
מאפיינים כללים
Model
D-LINK DPR-1061
Protocols
TCP/IP, NetBEUI
Manufacturer part number
DPR-1061
Warranty
1 Year
Type
Multi-print server, Simultaneous operation of 3 multifunction connected printers
I/O ports
2 USB 2.0 ports 1 parallel port LPT 1 port 10/100BASE-TX Ethernet LAN Power connector
Memory
SDRAM: 8 MB Flash ROM: 2 MB
OS Support
Windows 95/98/Me, Windows NT, Windows 2000/XP/2003 NetWare 5.x LPR Remote Printing (TCP/IP) HP-UX Unix, Sun OS, Solaris, SCO UNIX, AIX Unixware, Linux Mac OS Appletalk
Standarts
IEEE 1284 USB 2.0
LED
Power (food) Link / Activity USB1, USB2, LPT / Activity
Power supply
Through an external power adapter, 5V
Dimensions
148 x 114 x 31 mm
נתונים פיזיים
תקנים
הורדות
איורים
DPR-1061
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
