DUB-E100EOL EOS
Fast Ethernet USB 2.0 adapteris
Aprašymas
USB 2.0 for True 10/100Mbps Speed
The USB port of the adapter gives you throughput of up to 480Mbps to your computer. That's about 40 times faster than USB 1.1, the earlier USB specification. Now you can take full advantage of your Fast Ethernet network speed to transfer files, send e-mail and upload/download images.
USB Plug-and-Play
As a USB device, this adapter eliminates the need to open your computer's cover to plug a network card into an expansion slot. It also saves your notebook's PC Card slot for other use. Installation and use are further simplified by living up to USB's out-of-the-box installation approach to connecting computer peripherals. You will not have to set IRQ's and other settings for your network connection. configuration is automatic at computer power up, and the adapter is hot pluggable. The DUB-E100 is equipped with an attached USB 2.0 cable that directly connects to any USB port on your computer. It is backward compatible with USB 1.1, so you can use the adapter with USB 1.1 ports as well (in case no USB 2.0 port is available). The DUB-E100 represents the simplest way to connect your computer to an Ethernet-based network.
Energy Saving Suspend/Resume Function
The DUB-E100 supports USB's energy saving suspend and resume function to minimize power consumption, which is especially useful for laptop/notebook users. Power is provided directly by the USB bus, eliminating the need for an external AC power adapter .
Bendros charakteristikos
Sertifikatai
Informacija užsakymui
Paveikslas
DUB-E100/Cx
Vaizdas iš priekio
Vaizdas iš galo
Vaizdas iš galo
Parsisiuntimui
Taip pat žiūrėkite
