DEM-412XEOL EOS
2-Port 10-Gigabit Module with XFP Slot for DXS-3250E
Apraksts
The D-Link® DEM-412X is a 2-port 10-Gigabit XFP Module for the xStack DXS-3250E switch. Fiber XFP is a means of transporting data over long distances at speeds up to 10Gbps. The DEM-412X is fully IEEE 802.3ae compliant and supports data transfer at full duplex for congestion-free data transport. The DEM-412X supports industry standards and may be compatible with 3rd party XFP transceivers. The DEM-412X can be used to interconnect switches, uplink to servers or provide a clean fiber bandwidth channel for SAN and other network storage devices. For a complete solution, the DEM-421XT 10GBase-SR XFP can be added for fiber runs over multi-mode cabling up to 300 meters. If longer hauls are required, D-Link offers the DEM-422XT single-mode 10GBase-LR XFP capable of distance runs up to 10Km.
Īpašības
Product specifications
Module
• Compliant with IEEE 802.3ae
• Supports Full-Duplex operation only
• 2 open XFP transceiver slots
Physical & Enviornmental
Dimensions (D x W x H)
• 5.25” x 3.95” x 1.15” (133.35mm x 100.33mm x 29.21mm)
Weight
• 0.32 lbs (145.15 g)
Temperature
• Operating: 32° to 122°F (0° to 50°C)
• Storage: -36°F to 126°F (-20°C to 70°C)
Humidity
• Operating: 90% (Non condensing)
Warranty and Support Information
Warranty
• Limited Lifetime Warranty*
Support
• Free Technical Support
Ordering Information
Part Number
• Description
DEM-412X
• 2-Port 10-Gigabit Module with XFP Slot for DXS-3250E (XFP sold separately)
DEM-421XT
• 10GBASE-SR Multi-Mode XFP (up to 300m)
DEM-422XT
• 10GBASE-LR Single-Mode XFP (up to 10km)
Sertifikāti
Informācija pasūtījumam
DEM-412X 1 por t 10GE XFP module
Attēli
DEM-412X/A
View from the right
Pārlādēt
Skatiet arī
