DES-1016AEOL EOS
Apraksts
CREATE A WIRED NETWORK INSTANTLY
With D-Link DES-1016A and DES-1024A, you can easily expand your network by adding more computers or devices with speeds up to 200 Mbps per port in fullduplex mode.
AUTO-SENSING 10/100 PORTS
The DES-1016A and DES-1024A both use auto-sensing 10/100 Mbps ports, allowing a small workgroup to flexibly connect to 10 or 100Mbps devices to create an integrated network. Each port automatically adjusts for straight-through or crossover cables to make the right link.
FLOW CONTROL FOR SECURE TRANSMISSION
802.3x Flow Control on each port minimizes dropped packets when the port’s receiving buffer is full.
Īpašības
KEY FEATURES
Inexpensive Fast Ethernet solution for
SOHO/SMB
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet
Speeds
• IEEE 802.3x Flow Control
• Plug-and-play installation
SWITCHING FABRIC
3.2 Gbps switching fabric
STANDARDS
• IEEE 802.3 10BASE-T Ethernet (twistedpair copper)
• ANSI/IEEE 802.3 NWay Auto-Negotiation
PROTOCOL
CSMA/CD
DATA TRANSFER RATES
Ethernet:
• 10 Mbps (half duplex)
• 20 Mbps (full duplex)
Fast Ethernet:
• 100 Mbps (half duplex)
• 200 Mbps (full duplex)
NUMBER OF PORTS
16 10/100Mbps Fast Ethernet ports
TOPOLOGY
Star
NETWORK CABLES
10BASE-T:
• UTP CAT 3/4/5/5e (100 m max.)
• EIA/TIA-586 100-ohm STP (100 m max.)
100BASE-TX:
• UTP CAT 5/5e (100 m max.)
• EIA/TIA-568 100-ohm STP (100 m max.)
MEDIA INTERFACE EXCHANGE
Auto MDI/MDIX adjustment for all ports
LED INDICATORS
• Per port: Link/Activity
• Per device:Power
TRANSMISSION METHOD
Store-and-forward
MAC ADDRESS TABLE
8K entries per device
MAC ADDRESS LEARNING
Automatic update
PACKET FILTERING/FORWARDING RATES (HALF DUPLEX)
• Ethernet: 14,880 pps per port
• Fast Ethernet: 148,800 pps per port
RAM BUFFER
256K Bytes (2M bits)
