DES-1210-08PEOL EOS
8-Port Web Smart Switch
Kur iegādāties
Apraksts
The DES-1210 Series is the latest generation of D-Link Web Smart switches. Equipped with 24 or 48 10/100 Mbps ports, 2 10/100/1000BASE-T ports, and 2 combo 10/100/1000BASE-T/SFP ports, the DES-1210 Series integrates advanced management and security functions for enhanced performance and scalability. The DES-1210-08P/28P are built with 10/100 Mbps ports that are PoE-enabled, offering ease-of-use and green features such as Timebased PoE, which can shut off PoE power at a predetermined time. The Smart Fan feature on the DES-1210-28P allows the built-in fans to automatically turn on at a certain temperature, providing continuous, reliable, and eco-friendly operation of the switch. Compliant with 802.3af and 802.3at, the DES-1210-28P is capable of feeding power of up to 30 watts to devices. Management options include SNMP, Web Management, SmartConsole Utility, and Compact Command Line for easy deployment. The DES-1210 Series provides a complete and affordable solution that is ideal for small and medium businesses and the enterprise edge.
Seamless Integration
The Web Smart switches are designed to provide SMB users with complete control over their network. With Ethernet and Gigabit copper ports capable of connecting to existing CAT5 twisted-pair cables, these switches eliminate the need for complex reconfiguration. The DES-1210 Series allows for flexible connection to a backbone or server. Additionally, all ports support auto-negotiation of MDI/MDIX crossover, eliminating the need for crossover cables or uplink ports.
Extensive Layer 2 Features
Equipped with a complete lineup of L2 features, these switches include IGMP Snooping, Port Mirroring, Spanning Tree, and Link Aggregation Control Protocol (LACP). IEEE 802.3x Flow Control allows servers to directly connect to the switch for reliable data transfer. At 2000 Mbps full-duplex, the Gigabit ports provide high-speed data pipes to servers with minimum data transfer loss. Network maintenance features include Loopback Detection and Cable Diagnostics. Loopback Detection is used to detect loops created by a specific port and automatically shuts down the affected port. Cable Diagnostics allow network administrators to quickly examine the quality of the copper cables and also determine the type of cable error.
QoS & Bandwidth Control
The DES-1210 Series switches support Auto Surveillance VLAN (ASV) and Auto Voice VLAN for VoIP and video surveillance deployments. ASV ensures the quality of real-time video for monitoring and control without compromising the transmission of conventional network data. DSCP markings on Ethernet packets enable different levels of service to be assigned to network traffic. In addition, with Bandwidth Control, network administrators can reserve bandwidth for important functions that require more bandwidth or require high priority.
Secure Your Network
D-Link’s innovative Safeguard Engine protects against traffic flooding caused by virus attacks. These switches also support 802.1X port-based authentication, allowing the network to be authenticated through external RADIUS servers. In addition, the Access Control List (ACL) feature enhances network security and protects the internal IT network. The DES-1210 Series supports ARP Spoofing Prevention, which prevents the network from being cut off or eavesdropped by hackers using faked ARPs that pretend to be PCs, servers, routers, or gateways. For added security, DHCP Server Screening screens rogue DHCP server packets from user ports to prevent unauthorized IP assignment.
Versatile Management
This new generation of Web Smart Switches provides growing businesses with simple and easy management of their network by using an intuitive SmartConsole utility and a web-based management interface that enables administrators to remotely control their network down to the port level. The SmartConsole allows customers to easily discover multiple D-Link Web Smart Switches within the same L2 network segment. With this utility, users do not need to change the IP address of their PC and it also provides an easy setup of the Smart Switches. Switches within the same L2 network segment that are connected to the user’s local PC are displayed on screen for instant access. This allows for extensive switch configuration settings and basic configuration (password changes and firmware upgrades) of discovered devices.
The DES-1210 Series supports D-View 6.0 and Compact Command Line Interface (CLI) control through Telnet. D-View 6.0 is a Network Management System that allows for central management of critical network characteristics and provides a useful set of tools for network administrators who want to effectively manage device configurations, fault tolerance, performance, and security. CLI management of switches is possible via Telnet, and allowing administrators to perform basic operations such as password changes, firmware upgrades, and configuration file uploads.
Īpašības
General
Size
7.5” Metal
Interface
8 10/100BASE-TX PoE
Port
• Standards IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
Auto-negotiation
Performance
• Switching Capacity: 1.6 Gbps
• 64-Byte Packet Forwarding Rate: 1.19 Mpps
• MAC Address Table: Size 8K Entries
• Packet Buffer Memory: 384 KB
• Flash Memory: 16 MB
• Forwarding Method: Store-and-forward
Power over Ethernet (PoE)
• PoE Standard: 802.3af
• PoE Capable Ports: Port 1-8 up to 15.4 watts per port
• PoE Power Budget: 72 watts
Diagnostic LEDs
• Power (Per Device)
• Link/Activity/Speed (Per Port)
L2 Features
• MAC Address Table: 8K entries
• Flow Control
  + 802.3x Flow Control
  + HOL Blocking Prevention
•IGMP Snooping
  + IGMP v1/v2 Snooping
  + Supports 256 IGMP snooping groups
  + Supports 64 static multicast addresses
  + Per VLAN IGMP snooping
  + Supports IGMP Querier
• L2 Multicast Filtering
  + Forwards all unregistered groups
  + Filters all unregistered groups
• Spanning Tree Protocol
  + 802.1D STP
  + 802.1w RSTP
• Loopback Detection
• 802.3ad Link Aggregation
  + Max. 8 groups per device, max. 8 ports per group
• Port Mirroring
  + One-to-One
  + Many-to-One
  + Supports Mirroring for Tx/Rx/Both
• Cable Diagnostics
• Configurable MDI/MDIX
VLAN
• 802.1Q tagged VLAN
• VLAN Group
  + Max. 256 static VLAN groups
  + Max. 4094 VIDs
• Management VLAN
• Asymmetric VLAN
• Auto Voice VLAN
  + Max. 10 user defined OUI
  + Max. 8 default OUI
• Auto Surveillance VLAN
QoS (Quality of Service)
• 802.1p
• Max. 8 queues per port, max. 8 ports per queue
• Queue Handling
  + Strict
  + Weighted Round Robin (WRR)
• CoS based on
  + 802.1p Priority Queues
  + DSCP
• Bandwidth Control
  + Port-based (Ingress/Egress, min. granularity 64 Kb/s for 10/100 Mbps and 1850 Kb/s for 1000 Mbps)
• Max. 50 ingress ACL profiles
• Max. 240 ingress ACL rules shared by profiles
• ACL based on:
  + MAC address
  + IPv4 address
  + ICMP/IGMP/TCP/UDP
• ACL Actions
  + Permit
  + Deny
Security
• 802.1X
  + Port-based access control
• Port Security
  + Supports up to 64 MAC addresses per port
• Broadcast/Multicast/Unicast Storm Control
• Static MAC
• D-Link Safeguard Engine
• DHCP Server Screening
• ARP Spoofing Prevention
  + Max. 64 entries
• SSL
  + Supports v1/v2/v3
Management
• Web-based GUI
• Compact CLI through Telnet
• Telnet Server
• SmartConsole Utility
• TFTP Client
• SNMP
  + Supports v1/v2/v3
• SNMP Trap
• Trap for SmartConsole Utility
• System Log
  + Max. 500 log entries
  + Supports IPv4 log server
• BootP/DHCP Client
• Time Setting
  + SNTP
• LLDP1
• LLDP-MED2
• Time-based PoE1
MIB
• 1213 MIB II
• 1493 Bridge MIB
• 1907 SNMP v2 MIB
• 1215 Trap Convention MIB
• 2233 Interface Group MIB
• D-Link Private MIB
• Power Ethernet-MIB1
• LLDP-MIB1
RFC Standard Compliance
• RFC 768 UDP
• RFC 783 TFTP client
• RFC 791 IP
• RFC 792 ICMP
• RFC 793 TCP
• RFC 826 ARP
• RFC 854, 855, 856, 858 Telnet Server
• RFC 896 Congestion Control in TCP/IP Network
• RFC 903 Reverse Address Resolution Protocol
• RFC 951 BootP Client
• RFC 1155 MIB
• RFC 1157 SNMP v1
• RFC 1191 Path MTU Discovery
• RFC 1212 Concise MIB Definition
• RFC 1213 MIB II, IF MIB
• RFC 1215 Traps for use with the SNMP
• RFC 1239 Standard MIB
• RFC 1350 TFTP
• RFC 1493 Bridge MIB
• RFC 1519 CIDR
• RFC 1542 BootP/DHCP client
• RFC 1901, 1907, 1908 SNMP
• RFC 1945 HTTP/1.0
• RFC 2131, 2132 DHCP
• RFC 2138 Radius Authentication
• RFC 2233 Interface MIB
• RFC 2570, 2575 SNMP
• RFC 2578 Structure of Management Information Version 2 (SMIv2)
• RFC 2647 802.1p
• RFC 3416, 3417 SNMP
• RFC 3621 Power Ethernet (PoE Model only)
Fiziskie raksturlielumi
MTBF (Hours)
350,704 hours
Acoustics
0 dB
Heat Dissipation
305.03 BTU per hour
Power Input
100 to 240 VAC, 50 to 60 Hz Internal Universal Power Supply
Max Power Consumption
• 89.4 watts (PoE on)
• 9.7 watts (PoE off)
Dimensions (W x D x H)
190 x 120 x 38 mm
Cooling Fans
Fanless
Operating Temperature
0 to 40˚ C
Storage Temperature
-10 to 70˚ C
Operating Humidity
5% to 95% non-condensing
Emission (EMI)
FCC Class A, CE Class A, VCCI Class A, IC, C-Tick
Safety
cUL, CE LVD
1 DES-1210-08P/28P only
2 DES-1210-28P only
Sertifikāti
Informācija pasūtījumam
DES-1210-08P 8-Port Web Smart Switch
Attēli
DES-1210-08P/A
Вид сзади
Skatiet arī
