7200-CM4Projektiem
CPU module for the DES-7210 chassis, switch fabric 192 Gbit/s, with ASE support
Kur iegādāties
Apraksts
The CPU module for the DES-7210 chassis, switch fabric 192 Gbit/s, with the support of ASE
Īpašības
Flash Memory
512MB
SDRAM
512MB (expandable to 1GB)
Fiziskie raksturlielumi
Power consumption
50W
Heat dissipation
170.61BTU/hr
MTBF (hours)
173.868
Sertifikāti
Informācija pasūtījumam
7200-CM4   CPU module for the DES-7210 chassis, switch fabric 192 Gbit/s, with ASE support
Attēli
7200-CM4
Skatiet arī
