Ātrā meklēšana
Produkta iespējas:
Layer 3 Stackable 10GbE Managed Switch
Projektiem
Īpašības:
Interfaces
• 24 fixed SFP+ 10G ports with one expansion module
Console Port
• RJ-45 console port for out-of-band management
Management Port
• 10/100/1000 Base-T RJ-45 Ethernet for out-of-band remote management
SD Card Slot
• 1 slot
Performance
Switching Capacity
• 960Gbps
Max. Forwarding Rate
• 714.28Mpps
Packet Buffer Memory
• 9 MB
MAC Address Table
• 128K
Standard Image (SI) Features
Stackability
• Physical Stacking
  • 480G stacking bandwidth
  • Up to 4 switches in a stack
  • Ring/chain topology support
• Virtual Stacking/Clustering of up to 32 units1
• Supports D-Link Single IP Management
L2 Features
• MAC Address Table
  • 128K entries
• Flow Control
  • 802.3x Flow Control when using Full Duplex
  • Back Pressure when using Half Duplex
  • HOL Blocking Prevention
• Spanning Tree Protocol
  • 802.1D STP
  • 802.1w RSTP
  • 802.1s MSTP
  • Supports Root Restriction
• Jumbo Frame
  • Up to 12,000 bytes
• 802.1AX Link Aggregation
  • Max. 16 groups per device, 12 ports per group
• ERPS1 (Ethernet Ring Protection Switching)
• Port Mirroring
  • Supports One-to-One, Many-to-One
  • Supports Mirroring for Tx/Rx/Both
  • Supports 4 mirroring groups
• Flow Mirroring
  • Supports Mirroring for Rx
• Loopback Diagnostics1
L2 Multicast Features
• L2 Multicast Filtering
  • Forwards all groups
  • Forwards all unregistered groups
  • Filters all unregistered groups
• MLD Snooping1
  • MLD v1/v2 Snooping
  • Supports 4K groups
  • Host-based MLD Snooping Fast Leave
• IGMP Snooping
  • IGMP v1/v2/v3 Snooping
  • Supports 4K IGMP groups
  • Supports 1K static multicast addresses
  • IGMP per VLAN
L3 Features
• ARP
  • 512 Static ARP
  • Supports Gratuitous ARP
• IP Interface
  • Supports 256 interfaces
• Loopback Interface1
L3 Routing
• Static Routing
  • Max. 1K IPv4 entries
  • Max. 512 IPv6 entries1
  • Supports route distribution
  • Supports secondary route
  • Supports Equal Cost/Weighted Cost multi-path route
• Default Routing
VLAN
• 802.1Q
• 802.1v
• Double VLAN (Q-in-Q)
  • Port-based Q-in-Q
  • Selective Q-in-Q
• Port-based VLAN
• MAC-based VLAN
• Subnet-based VLAN
• Private VLAN1
• VLAN Group
  • Max. 4K static VLAN groups
  • Max. 4094 VIDs
• GVRP
  • Up to 4K dynamic VLANs
AAA
• 802.1X Authentication
  • Supports Port-based access control
  • Supports Host-based access control
  • Dynamic VLAN Assignment
  • Identity-driven Policy (VLAN/ACL/QoS) Assignment
• Web-based Access Control (WAC)1
• MAC-based Access Control (MAC)1
• Guest VLAN
QoS (Quality of Service)
• 802.1p Quality of Service
• 8 queues per port
• Queue Handling
  • Strict
  • Weighted Round Robin (WRR)
  • Strict + WRR
  • Round Robin (RR)
  • Weighted Deficit Round Robin (WDRR)
• QoS based on
  • 802.1p Priority Queues
  • DSCP
  • IP address
  • MAC address
  • VLAN
  • IPv6 Traffic Class
  • IPv6 Flow Label
  • TCP/UDP port
Bandwidth Control
  • Port-based (Ingress/Egress, min. granularity 8 Kb/s)
  • Flow-based (Ingress/Egress, min. granularity 8 Kb/s)
  • Per queue bandwidth control (min. granularity 8 Kb/s)
• Three Color Marker
  • trTCM
  • srTCM
• Congestion Control
  • WRED
• Support for following actions:
  • Remark 802.1p priority tag
  • Remark TOS/DSCP tag
  • Bandwidth Control
  • Committed Information Rate (CIR)
Access Control List (ACL)
• ACL based on:
  • 802.1p priority
  • VLAN
  • MAC address
  • Ether Type
  • IP address
  • DSCP
  • Protocol type
  • TCP/UDP port number
  • IPv6 Flow Label
• Max. ACL entries:
  • 1792 ingress ACL rules
  • 1K egress ACL rules
  • 1K VLAN ACL rules
• Time-based ACL
Security
• Port Security
  • Supports up to 12K MAC addresses per port/system
• Broadcast/Multicast/Unicast Storm Control
• D-Link Safeguard Engine1
• DHCP Server Screening1
• IP-MAC-Port Binding1
  • ARP inspection
  • IP inspection
  • DHCP Snooping
• ARP Spoofing Prevention1
  • Max. 64 entries
• Traffic Segmentation
• SSL1
  • Supports v1/v2/v3
  • Supports IPv4/v6 access
• SSH
• BPDU Attack Prevention
• DOS Attack Prevention
Management
• Web-based GUI
• CLI
• Telnet
• TFTP Client
• FTP Client
• Traffic Monitoring
• SNMP
  • Supports v1/v2/v3
• SNMP Trap
• System Log
• DHCP Client
• DHCP Server
• DHCP Relay
• Multiple Image
• Multiple Configuration
• Flash File System
• DNS Resolver
• CPU Monitoring
• MTU Setting
• Traceroute
• LLDP
• DNS Relay
• SMTP1
• DHCP Auto Configuration
• SNTP
• RCP1
• RMONv1
• RMONv2
• Trusted Host1
• Password Encryption
• Debug Command
Enhanced Image (EI) Additional Features
L3 Multicasting
• Multicast Table Size: 2K
• IGMP v1, v2, v3
• PIM-SM
• PIM-DM
• PIM-Sparse-Dense Mode
• PIM-SSM
• DVMRP v3
• MLD v1/v21
MPLS
• LDP
• MPLS LSP trigger filtering
• MPLS label-forwarding
• MPLS QoS
• MPLS ping and traceroute
• L2 protocol tunneling through PW
• VPWS
• VPLS
• PW Redundancy
L3 Features
• IPv6 Tunneling
  • Static
  • ISATAP
  • GRE
  • 6to4
  • VRRP
L3 VPN
• MPLS/BGP L3 VPN
• VRF-Lite
• MP-BGP
• VRF aware application
L3 Routing
• Supports 16K hardware routing entries shared by IPv4/IPv6
  • Max. 16K IPv4 entries
  • Max. 8K IPv6 entries1
• Supports 8K hardware L3 forwarding entries shared by IPv4/IPv6
  • Max. 8K IPv4 entries
  • Max. 4K IPv6 entries1
• RIP
  • RIP v1/v2
  • RIPng1
• OSPF
  • OSPF v2
  • OSPF v31
  • OSPF Passive Interface
  • Stub/NSSA Area
  • OSPF Equal Cost Route
• BGPv4
• Route Redistribution
• IP Directed Broadcast
• Policy Based Route
Standards
MIB & RFC Standards
• RFC1213 MIB II
• RFC1907 SNMP v2 MIB
• RFC5519 IGMP v3 MIB
• RFC1724 RIP v2 MIB
• RFC2021 RMONv2 MIB
• RFC1643, RFC2358, RFC2665 Ether-like MIB
• RFC4836 802.3 MAU MIB
• RFC4363 802.1p MIB
• RFC4292 IP Forwarding Table MIB
• RFC2932 IPv4 Multicast Routing MIB
• RFC2934 PIM MIB for IPv4
• RFC2925 Traceroute MIB
• RFC2925 Ping MIB
• RFC1850 OSPF MIB
• Private MIB
• RFC1112, RFC2236, RFC3376, RFC4541 IGMP Snooping
• RFC4363 802.1v
• RFC2338 VRRP
• RFC1058, RFC1388, RFC1723, RFC2453, RFC2080 RIP
• RFC1370, RFC1765, RFC2328, RFC2740, RFC3101 makes RFC1587 obsolete, RFC2328 makes RFC1583, RFC2178 OSPF v2,v3
• RFC1771, RFC1997, RFC2439, RFC2796, RFC2842, RFC2918 BGP
• RFC3973 PIM-DM
• RFC5059 PIM-SM
• RFC3569, RFC4601, RFC4608, RFC4607, RFC4604 PIM SSM
• RFC3376 IGMP
• RFC2475 Priority Queue Mapping
• RFC2475, RFC2598 Class of Service (CoS)
• RFC2597, RFC2598 QoS Flow Actions
• RFC2697, RFC2698 Three Color MarkerRFC2093, RFC2904, RFC2095, RFC2906 AAA
• RFC1321, RFC2144, RFC2313, RFC2420, RFC2841, RFC3394 Encryption
• RFC2289 One-Time
• RFC3580 802.1X
• RFC2866 RADIUS Accounting
• RFC2138, RFC2139, RFC2865, RFC2618 RADIUS Author. for Management Access
• RFC1492 TACACS+ Auth. for Management Access
• RFC2068, RFC2616 Web-based GUI
• RFC854 Telnet Server
• RFC783, RFC1350 TFTP Client
• RFC1157, RFC1901, RFC1908, RFC2570, RFC2574, RFC2575, RFC3411-17 SNMP
• RFC3164 System Log
• RFC2819 RMON v1
• RFC951, RFC1542, RFC2131, RFC3046 BootP/DHCP Client
• RFC1769 Time Setting
• RFC2131 DHCP Server
• RFC1191 MTU Setting
• RFC1065, RFC1066, RFC1155, RFC1156, RFC2578 MIB Structure
• RFC4188 Bridge MIB
• RFC1157, RFC2571-2576, RFC3411-3415, RFC3418 SNMP MIB
• RFC1901-1908,RFC1442, RFC2578 SNMP v2 MIB
• RFC2737 Entity MIB
• RFC768 UDP
• RFC791 IP
• RFC792 ICMP
• RFC793 TCP
• RFC826 ARP
• RFC1338, RFC1519 CIDR
• RFC2716, RFC3748 EAP
• RFC2571, RFC2572, RFC2573, RFC2574 SNMP
Fiziskie raksturlielumi
Power Input
• 100 to 240 V AC, 50/60 Hz
Maximum Power Consumption
• 116.8 W (without expansion module)
• 160.4 W (with DXS-3600-EM-4QXS)
Standby Power Consumption
• 88.2 W
Heat Dissipation (Max.)
• 398.29 BTU/hr (without expansion module)
• 546.96 BTU/hr (with DXS-3600-EM-4QXS)
Heat Dissipation (Standby)
• 300.76 BTU/hr
Dimensions
• 440 x 506 x 44 mm
Weight
10.71 kg
Operating Temperature
• 0 to 45 °C
Storage Temperature
• 40 to 70 °C
Operating Humidity
• 0% to 95% RH
Storage Humidity
• 0% to 95% RH
Certifications
• CB, cUL
EMI/EMC
• FCC, CE, C-Tick, IC, VCCI, BSMI
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
