DPS-2500EOL EOS
Offline/Standby Uninterruptible Power Supply (UPS)
Apraksts
D-Link DPS-2500 Offline/Standby Uninterruptible Power Supply (UPS) is an efficient and reliable power system for networking applications. With external battery packs, it can back up network devices for long-term operation and will continue providing stable power to connected equipment and helps administrators to shut down networking devices safely during power failure to prevent any data loss. Its embedded microprocessor controller guarantees high reliability and is ideal for any network devices such as routers, switches, and access points. Audible alarm and front panel LEDs offer status information regarding line and battery power operation.
Management Options
The DPS-2500 includes a power management software to provide optimized management and protection for networking equipment. Remotely monitor and control this UPS by connecting it directly to the network. In addition, the DPS-2500 can be managed via a USB port.
Compact Design
The DPS-2500 comes in an attractive compact housing and offers uninterrupted power protection against surges and spikes while encountering a power failure.
Battery Options
The DPS-2500 does not include any internal batteries. D-Link recommends using a standard 12-volt battery with any amperage.
Tip: Most car batteries can be used with the DPS-2500.
Īpašības
Communication Interface
Type: USB
Sertifikāti
Informācija pasūtījumam
