DES-1016D/F1EOL EOS
16-Port 10/100 Switch
Apraksts
IDEAL FOR BASIC NETWORKING TASKS
With the D-Link DES-1016D, you can easily expand your network by adding more computers or devices with speeds up to 200Mbps per port in full-duplex mode.
AUTO-SENSING 10/100 PORTS
The DES-1016D uses auto-sensing 10/100Mbps ports, allowing a small workgroup to flexibly connect to 10 or 100Mbps devices to create an integrated network. Each port automatically adjusts for straight-through or crossover cables to make the right link.
FLOW CONTROL FOR SECURE TRANSMISSION
802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full.
QUALITY OF SERVICE (QOS)
The switch provides 802.1p priority queues for QoS, allowing users to run bandwidth-sensitive applications such as multimedia and VoIP Internet telephone without data flow bottlenecks that can degrade the quality of the network connection.
SAVE ON ENERGY COSTS
The switch supports IEEE802.3az EEE which enables the switch to reduce power consumption when the switch is at low utilization, allowing users to save on power usage and costs. During these periods of low utilization, the switch can enter a low-power state and use up less power than regular operations.
Īpašības
Key features
• Inexpensive Fast Ethernet solution for SOHO/SMB
• Auto MDI/MDIX crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Plug-and-play installation
Switching fabric
• 3.2Gbps
Standards
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.3x flow control
• IEEE 802.3az EEE function
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Number of ports
• 16 10/100Mbps Fast Ethernet ports
Topology
• Star
Network cables
10BASE-T:
• UTP CAT 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX:
• UTP CAT 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
LED indicators
• Per port: Link/Activity
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 8K
MAC address learning
• Automatic update
Packet filtering/forwarding rates (half duplex)
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
RAM buffer
• 256 Bytes per device (2M bits)
Power input
• 100~240V AC 50/60Hz internal universal power supply
Sertifikāti
Informācija pasūtījumam
DES-1016D/F1  16-Port 10/100 Switch
Attēli
DES-1016D/F1/F1
View from the right
Back view
Pārlādēt
Skatiet arī
