Ātrā meklēšana
Produkta iespējas:
16-Port 10/100 Switch
EOL EOS
Īpašības:
Key features
• D-Link Green Technology
  • Power saving by cable length detection and link status
• Inexpensive Gigabit solution for SOHO/SMB
• Silent, fanless design
• Auto MDI/MDI-X crossover for all ports
• Store-and-forward switching scheme
• Full/half-duplex for Ethernet/Fast Ethernet speeds
• IEEE 802.3x Flow Control
• Supports 9,600 Bytes Jumbo Frames
• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
• Supports Cable Diagnostics Function
• Supports D-Link’s unique EEE+ mode
• RoHS compliant
• Plug-and-play installation
Number of ports
• 16 Gigabit ports
Switching fabric
• 32Gbps
Standards
• IEEE 802.3ab 1000BASE-T Gigabit Ethernet (twisted-pair copper)
• ANSI/IEEE 802.3 NWay auto-negotiation
• IEEE 802.1p QoS (4 queues, strict mode)
• IEEE 802.3az EEE
Protocol
• CSMA/CD
Data Transfer Rates
Ethernet:
• 10Mbps (half duplex)
• 20Mbps (full duplex)
Fast Ethernet:
• 100Mbps (half duplex)
• 200Mbps (full duplex)
Gigabit Ethernet:
• 2000Mbps (full duplex)
Topology
• Star
Network cables
10BASE-T:
• UTP CAT 3, 4, 5/5e (100m max.)
• EIA/TIA-586 100-ohm STP (100m max.)
100BASE-TX, 1000BASE-T:
• UTP CAT 5/5e (100m max.)
• EIA/TIA-568 100-ohm STP (100m max.)
Media interface exchange
• Auto MDI/MDIX adjustment for all ports
LED indicators
• Per port: Link/Activity/Speed
• Per device: Power
Transmission method
• Store-and-forward
MAC address table
• 8K entries per device
MAC address learning
• Automatic update
Packet filtering/forwarding rates (half duplex)
• Ethernet: 14,880pps per port
• Fast Ethernet: 148,800pps per port
• Gigabit Ethernet: 1,488,000pps per port
RAM buffer
• 512KB per device
Fiziskie raksturlielumi
Power consumption
Standby: 3.8 watts
Maximum: 11.0 watts
Heat dissipation
• Standby: 12.958BTU/h
• Maximum: 37.51BTU/h
Acoustics
• 0 dB
MTBF
• 1,087,450 hours
Operating temperature
• 0 to 40°C
Storage temperature
• -10 to 70°C
Storage humidity
• 5% to 90% RH non-condensing
Device dimensions (W x D x H)
• 280 x 180 x 44mm
Weight
• 1.59kg
Certifications
• FCC Class A
• ICES-003 Class A
• CE Class A
• C-Tick Class A
• VCCI Class A
• cUL
• CB
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
