DGS-1008A/C1EOL EOS
8-Port Gigabit Switch
Apraksts
	The DGS-1008A 8-Port Gigabit Switch is part of D-Link’s new series of SOHO devices that make use of D-Link’s Green Technology, providing energy savings, reduced heat, and a longer product life without sacrificing performance or functionality. It provides eight Gigabit ports for easy expansion of your network and a quick way to upgrade your network to Gigabit connectivity. An energy-efficient power adapter (Energy Star Level V qualified), minimized use of harmful substances (RoHS compliant), and recyclable packaging make this switch truly environmentally friendly.
	Fast and Reliable Networking
	The D-Link DGS-1008A 8-Port Gigabit Switch creates a blazing fast network for your office, as its Gigabit Ethernet ports provide high-speed wired connections for up to eight PCs or other devices. The DGS-1008A also features QoS, which prioritizes network traffic so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. It’s stylish, easy-to-use, and comes IPv6-ready for a reliable network today and tomorrow.
	Conserve Energy
	The 8-Port Gigabit Switch helps you conserve energy automatically through several methods. It automatically powers down ports that have no link, allowing the switch to save a substantial amount of power by cutting power usage for unused ports. It also adjusts the amount of power supplied to a port according to the length of the connected Ethernet cable.
	Environmentally-friendly
	The 8-Port Gigabit Switch was designed with the environment in mind, and is compliant with Energy Star Level V, as well as with the stringent CEC and MEPS regulations that require the use of energy efficient power adapters. The switch is also built to follow RoHS standards to minimize the use of hazardous materials, and uses recyclable packaging that helps reduce waste, complying with the WEEE directive.
Īpašības
	Device Interfaces
	• Eight 10/100/1000 Gigabit LAN ports
	Functionality
	Advanced Features
	• Green Ethernet
	• 16Gbps switching fabric
	• Auto MDI/MDIX crossover for all ports
	• Secure store-and-forward switching scheme
	• Full/half-duplex for Ethernet/Fast Ethernet speeds
	• IEEE 802.3x Flow Control
	• Supports 9,216 Byte Jumbo Frames
	• Supports IEEE 802.1p QoS (4 Queues, Strict Mode)
	• Supports Cable Diagnostics Function
	Protocol
	• CSMA/CD
	Data Transfer Rates
	Ethernet:
	• 10Mbps (half duplex)
	• 20Mbps (full duplex)
	Fast Ethernet:
	• 100Mbps (half duplex)
	• 200Mbps (full duplex)
	Gigabit Ethernet:
	• 2000Mbps (full duplex)
	Transmission Method
	• Store-and-forward
	MAC Address Table
	• 8K
	MAC Address Learning
	• Automatic Update
	Packet Filtering/Forwarding Rates
	• Ethernet: 14,880pps per port
	• Fast Ethernet: 148,800pps per port
	• Gigabit Ethernet: 1,488,000pps per port
	RAM Buffer
	• 128KB per device
Sertifikāti
Informācija pasūtījumam
DGS-1008A/C1 8-Port Gigabit Switch
