Ātrā meklēšana
Produkta iespējas:
8-Port Unmanaged Switch with 8 PoE Ports
Īpašības:
Standards
IEEE 802.3 10BASE-T Ethernet (twisted-pair copper)
IEEE 802.3u 100BASE-TX Fast Ethernet (twisted-pair copper)
ANSI/IEEE 802.3 NWay auto-negotiation
IEEE 802.3x flow control
IEEE 802.3af Power over Ethernet
IEEE 802.3at Power over Ethernet
LAN
IEEE 802.3 10BASE-T
IEEE 802.3u 100BASE-TX compliance
IEEE 802.3x Flow Control support
Data Transfer Rates
Fast Ethernet
100 Mbps Half-Duplex
200 Mbps Full-Duplex
Ethernet
10 Mbps Half-Duplex
20 Mbps Full-Duplex
Functionality
Port Packet Filtering/Forwarding Rate
148,800 pps for 100 M
14,880 pps for 10 M
Switching Fabric
1.6 Gbps switching fabric
Number of Ports
8 10/100 Mbps Fast Ethernet ports
8 PoE ports
Network Cables
10BASE-T:
   • UTP CAT 3/4/5/5e (100 m max.)
   • EIA/TIA-586 100-ohm STP (100 m max.)
100BASE-TX
   • UTP CAT 5/5e (100 m max.)
   • EIA/TIA-568 100-ohm STP (100 m max.)
Media Interface Exchange
Auto MDI/MDIX adjustment for all ports
LED Indicators
Link/Activity (per port)
Power (per device)
Transmission Method
Store-and-forward
MAC Address Table
2K entries per device
MAC Address Learning
Automatic update
Packet Filtering/Forwarding Rates
Ethernet: 14,880 pps per port
Fast Ethernet: 148,800 pps per port
RAM Buffer
96K bytes
Topology
Star
Protocol
CSMA/CD
Physical
Dimensions
280 x 125.8 x 44 mm (11.0 x 5.0 x 1.7 inches)
Weight
1.65 kg (3.63763lbs)
Power Consumption
Power On (Standby, no PD device connected)
  • AC input: 6.9 watts maximum
Maximum: (with 140W PoE device connected)
  • AC input: 146 watts
Heat Dissipation
  • AC input: 22.67 BTU/h
  • AC input: 486.7 BTU/h
MTBF
64,207 hours
Temperature
Operating: 0 to 40 °C (32 to 104 °F)
Storage: -40 to 70 °C
Humidity
Operating: 0% to 95% non-condensing
Storage: 0% to 95% non-condensing
Certifications
FCC
CE
CB
CCC
UL/cUL
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
