DGS-1016CEOL EOS
16-Port 10/100/1000 Mbps Unmanaged Switch
Apraksts
The DGS-1016C 10/100/1000 Mbps Unmanaged Switch is economical,plug-and-play networking switch solution for SOHO and small and medium businesses wanting to benefit from the increased bandwidth of Gigabit Ethernet. It provides 16 10/100/1000 Mbps ports that enable you to easily expand your network and provide a quick way to upgrade your network to fast connectivity.
Upgrade to Gigabit Networking
With data transfer speeds of up to 2000 Mbps at full duplex, this switch is ideal for quick file transfers, online gaming and smooth streaming media. It features easy-to-access Ethernet ports with LED indicators per port to easily distinguish link status. Auto MDI/MDIX crossover makes connection a cinch; just plug in your cables and you’re ready to go.
Conserve Energy
The DGS-1016C implements 802.3az Energy Efficient Ethernet, which saves energy and reduces heat automatically without sacrificing performance or functionality. The switch can detect when a connected computer is shut down or when there is no Ethernet traffic and can automatically reduce the power used for that port, cutting power usage substantially. In addition, the switch optimizes power usage for each port for the length of cable connected to it, using only as much power as is required. Both of these features work together to help you save power automatically.
Reliable Plug and Play Installation
The DGS-1016C is Plug-and-Play device that requires no configuration, so setup is simple and hassle-free, and you can easily connect multiple computers, share files, music, and video across your home or small office network, or even create a multiplayer gaming environment. 802.3x flow control on each port minimizes dropped packets when the port’s receiving buffer is full, giving you a more reliable connection for all of your connected devices.
Smooth Streaming
This switch supports QoS, which prioritizes network traffic so that time-sensitive data is delivered efficiently, even during bursts of high data traffic. This helps ensure an optimal experience for streaming media and VoIP calls.
Īpašības
Аппаратная версия
A1
B1
Device Interfaces |
16 10/100/1000 Mbps LAN ports
Standards |
IEEE 802.3 10BASE-T
IEEE 802.3u 100BASE-TX
IEEE 802.3ab 1000BASE-T
IEEE 802.3x Flow Control
IEEE 802.1p QoS
IEEE 802.3az Energy-Efficient Ethernet (EEE)
Switching Capacity |
32 Гбит/с
Метод коммутации
Store-and-forward
Advanced Features |
Auto MDI/MDIX crossover for all ports
Secure store-and-forward switching scheme
Full/half-duplex for Ethernet/Fast Ethernet speeds
Supports 9,216 byte jumbo frames
Back pressure at half-duplex operation
Wire-speed reception and transmission
Store and-Forward switching method
Auto-negotiation for each port
QoS (8 queues, strict mode)
Data Transfer Rates |
Ethernet:
10 Mbps (half duplex)
20 Mbps (full duplex)
Fast Ethernet:
100 Mbps (half duplex)
200 Mbps (full duplex)
Gigabit Ethernet
2000 Mbps (full duplex)
Transmission Method | Store-and-forward | |
MAC Address Table Size | 8,000 | |
Packet Filtering/Forwarding Rates |
Ethernet: 14,880 pps per port
Fast Ethernet: 148,800 pps per port
Gigabit Ethernet: 1,488,000 pps per port
RAM Buffer |
256 KB per device
512 KB
Physical | ||
LED Indicators |
Per port: Link/Activity/Speed
Per device: Power
Media Interface Exchange | Auto MDI/MDIX adjustment for all ports | |
Dimensions |
280 x 178 x 44 mm
280 x 126 x 44 mm
Weight |
1,06 kg
0,87 kg
Power |
100 to 240 V AC
External power adapter (12V/1A)
Power Consumption |
Power On (Standby): 4.48 watts
Maximum: 9.3 watts
Power On (Standby): 4.1 watts
Maximum: 11.7 watts
MTBF
208124 hours
305171 hours
Maximum Heat Dissipation |
33.55 BTU/h
39.92 BTU/h
Temperature |
Operating: 0 to 40 °C (32 to 104 °F)
Storage: -40 to 70 °C (-40 to 158 °F)
Humidity |
Operating: 10% to 90% non-condensing
Storage: 5% to 95% non-condensing
Certifications | ||
EMI
CE Report
EN 55022 & EN 55024
EN 61000-3-2
EN 61000-3-3
EN 61000-4-2/3/4/5/6/ 8/11(ESD/RS/FET/ Surge/CS/Magentic/Dip)
CE Report
EN 55022 & EN 55024
FCC report
FCC CFR 47 Part 15 Subpart B & ANSI C63.4 (включая ITE & Home Plug)
IC report
ICES-003 (ITE)
C-Tick Report
AS/NZS CISPR 22 (ITE)
VCCI Report
V-3 & V4
BSMI Report
CNS 13438
CCC
Safety |
CE (LVD report)
EN60950-1
cUL Listed Mark
UL/CSA 60950-1
CB Report
IEC 60950-1
EN 60950-1
CE (LVD report)
CCC
GB4943-2001
GB9254-1998
GB17625.1-2003
BSMI
CNS 14336-1
Sertifikāti
Informācija pasūtījumam
DGS-1016C 16-Port 10/100/1000 Mbps Unmanaged Switch
