DXS-PWR300ACProjektiem
300 W AC Power Supply with a Fan for the DXS-3400 and DXS-3600 Switches
Kur iegādāties
Apraksts
DXS-PWR300AC is a 300 W AC Power Supply with a fan (front-to-back air flow) for the DXS-3400 and DXS-3600 Switches.
Īpašības
Features
Output Power
• 300 W
Input Voltage Range
• 85~264 VAC
Input Frequency
• 47~63 Hz
Max. Input Current
• 4.31 A @ 85 VAC
Max. Inrush Current
• 30 A @ 264 VAC
Efficiency
• 88%
Physical Parameters
Dimensions (L x W x H)
• 27.5 х 7.9 х 4 cm
Weight
• 1.01 kg
MTBF
• 221 538 hours
Temperature
• Operating: -5 to 50 °C
• Storage: -40 to 70 °C
Humidity
• Operating: 0 to 95% non-condensing
• Storage: 0 to 95% non-condensing
Fiziskie raksturlielumi
Sertifikāti
Informācija pasūtījumam
DXS-PWR300AC  300 W AC Power Supply with a Fan for the DXS-3400 and DXS-3600 Switches
Attēli
DXS-PWR300AC/A
Skatiet arī
