DGS-3324SRiEOL EOS
Apraksts
The D-Link xStack Layer 3 Gigabit switches are stackable switches that combine performance with physical star stacking fault tolerance, robust security, quality of service (QoS), versatile management functions with scalable flexibility. All these features typically found in the more expensive chassis-based solutions, at the price of a stackable. A stack can provide up to 312 Gigabit ports * in the star architecture, and 336 Gigabit ports ** for the ring topology. 10Gigabit uplinks are available as optional modules, each with 2 XFP slots for transceivers capable of transmission at 20,000Mbps in the full duplex mode.
High-Speed Stacking. Each switch is equipped with 2 stacking ports providing 20Gbps full duplex bandwidth. Up to 6 units can be stacked with a Stacking Master, itself equipped with 6 stacking ports providing 120Gbps aggregated stacking bandwidth. Star stacking provides fault tolerance, as units can be added or removed without interrupting the service of the entire stack. The switches are stacked together through high-speed stack cables, allowing the entire stack to operate as a single high-performance entity. Alternatively, for installation sites with fewer switches to stack, shared 40Gbps ring stacking topology can be employed, so you don't have to add a Stacking Master.
Easy Expansion Beyond Physical Stack. With D-Link Single IP Management support, you can easily add up to 32 switch units per stack (not limited to any specific models) outside of your physical stack. Multiple switches can be configured, monitored and maintained from any workstation running a web browser through one single IP address. The stack is managed as a single object, and all stacked units are identified by a single IP address. A simple yet powerful web-based interface allows you to perform most management and configuration tasks, eliminating the need for you to install expensive, complex SNMP network management software.
Comprehensive Security. A complete set of security features is provided for connectivity and access control. This set includes Access Control Lists (ACLs) based on MAC address, switch port, IP address, and/or TCP/UDP port numbers, 802.1x user authentication and MAC address control. The xStack also provides central management for administration access via TACACS/TACACS+ and RADIUS. Together with network application control, this security ensures that not only proper user access is served, but malicious traffic is also prevented from being spread across the network. VLAN support includes GARP/GVRP and 802.1Q to enhance network security and performance. Bandwidth control allows you to set traffic limit for each port to control the traffic volume from the edge of the network. The switch implements a robust set of multi-layer (L2, L3, L4) QoS/CoS features to ensure that critical network services like VoIP , ERP, Intranet and video conference are served with proper priority. Up to 8 priority queues for 802.1p/TOS/DiffServ are supported, with classification and marking based on MAC SA/DA, IP SA/DA, and/or TCP/UDP port numbers. Virtual Router Redundancy Protocol (VRRP) allows several L3 switches on a multi-access link to utilize the same virtual IP address. One switch will be elected as a master with the other switches acting as backups in case of the failure of the master router. This VRRP support provides convenience, permitting your host system to be configured manually or via DHCP with a single default gateway.
Īpašības
Interface
- 2410/100/1000BASE-T Ports
- Auto-Negotiation of Network Speed
- Auto-MDI/MDIX
- 802.3x Flow Control
- 8 SFP*
- Compact Flash Slot
- RS-232 Console Port
Physical Stacking
- 6 SIO Stacking Ports
- Stacking Port Speed: 20Gbps (Full-Duplex)
- 7 No. of Units Per Stack (Star Topology) ***
- 12 No. of Units Per Stack (Ring Topology) ****
Performance
Switch Fabric
186GB
Packet Forwarding Rate
125Mpps
Packet Buffer Size
2MB
IP Address Table
3K
MAC Address Table
16K
Max. Jumbo Frame Size
9KBytes
Software Functions
IP Routing
- IP v.4 support
- IP Fragmentation support
- Multiple IP interfaces per VLAN
- Routing protocols supported:
Static routing
RIP v.1, RIP v .2
OSPF v.2
VLAN
- Port-based VLAN
- IEEE 802.1Q Tagged VLAN
- GARP/GVRP
- Maximum number of VLANs
- Dynamic: 255
- Static: 4K
Priority Queues (CoS)
- Standard: IEEE 802.1p
- Maximum number of queues: 8
Traffic Classification (CoS)
Can be based on user-definable application types:
- MAC address
- TOS
- Diffserv (DSCP)
- IP address
- Packet protocol type
- TCP/UDP port number (user-definable application types)
- TCP/UDP payload (user-definable packet content)
- IP v.6 address
- IP v.6 traffic class
- IP v.6 flow label
Access Security
- 802.1x port-based access control
- 802.1x MAC-based access control
- Port security
- SSH
- SSL
Access Control List
Multi-layer ACL based on:
- MAC address
- TOS
- Diffserv (DSCP)
- IP address
- Per port ACL definition
- IP v.6 address
- IP v.6 flow label
- CPU interface filtering
Spanning Tree Protocol
- 802.1D Spanning Tree compatible
- 802.1w Rapid Spanning Tree
- 802.1s Multiple Spanning Tree
IP Multicast
- IGMP v.2
- DVMRP
- PIM Dense mode
- PIM Sparse mode*
- VRRP
Port Trunk
- Maximum number of ports per trunk: 8
- Maximum number of trunks per stack: 32
- Operation mode support: load sharing
- 802.3ad compatible Link Aggregation (LACP)
Transmission Method
Store-and-Forward
Jumbo Frame
9KB (max.)
Configuration & Management
Management Support
- D-Link SIM (Single IP Management)
- SNMP v.1, v .2c, v.3
- Web-based management
- Web GUI traffic monitoring
- Web-based MAC address browsing
- CLI (command line interface)
- RMON monitoring
- Telnet server (up to 8 sessions)
- TACACS/TACACS+ authentication on switch admin access
- RADIUS authentication on switch admin access
- SYSLOG
- DHCP/Bootp relay
- DNS relay
- Dual Images
- Port description
- CPU utilization monitoring
MIBs
- MIB-II (RFC 1213)
- Bridge MIB (RFC 1493)
- RMON MIB (RFC 1757)
- 802.1p Priority Queues (RFC 2674)
- 802.1Q VLAN MIB (RFC 2674)
- IGMP MIB (RFC 2833)
- If MIB (RFC 2233)
- Ethernet-like MIB (RFC 1643)
- RIP MIB (RFC 1724)
- OSPF MIB (RFC 1850)
- CIDR MIB (RFC 2096)
- D-Link enterprise MIB
RMON Groups
1, 2, 3, 9 (Alarm, Statistics, History, Event)
IP Number Self-identification
Through DHCP client, Bootp client
Firmware Upgrade
TFTP
* Combo with 10/100/1000BASE-T ports.
** Combo with SFP slots.
*** Including DGS-3324SRi Stacking Master. Star stacking requires a DGS-3324SRi Stacking Master.
**** In the ring stacking scheme, maximum 12 units per stack if only
DGS-3324SR, DES-3352SR and DXS-3326GSR (any combination) are used. If
DXS-3350SR is included in the stack, maximum number of units per stack
will be less than 12.
Sertifikāti
Informācija pasūtījumam
DXS-3350SR 48 10/100/1000Mbps Ports Layer 3 Stackable Switch with 4 SFP Combo ports and optional 2-port 10GE uplink module
Optional Products
Optional Management Software
DS-510S D-View 5.1 SNMP Network Management Program (standard version)
DS-510P D-View 5.1 SNMP Network Management Program (professional version)
Optional 10Gigabit Uplink Modules
DEM-420X 2-slot 10Gigabit XFP uplink module
DEM-420CX 2-port 10Gigabit CX4 uplink module
Optional 10Gigabit XFP Transceivers
DEM-421XT XFP transceiver for 10GBASE-SR, multi-mode fiber, max. distance 300 m, 3.3/5V
DEM-422XT XFP transceiver for 10GBASE-LR, single-mode fiber, max. distance 10 km, 3.3/5V
DEM-423XT XFP transceiver for 10GBASE-ER, single-mode fiber, max. distance 40 km, 3.3/5V
Optional SFP Transceivers
DEM-310GT SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 10 km, 3.3V
DEM-311GT SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 550 m, 3.3V
DEM-312GT2 SFP transceiver for 1000BASE-SX, multi-mode fiber, max. distance 2 km, 3.3V
DEM-314GT SFP transceiver for 1000BASE-LHX, single-mode fiber, max. distance 50 km, 3.3V
DEM-315GT SFP transceiver for 1000BASE-LX, single-mode fiber, max. distance 80 km, 3.3V
Optional Redundant Power Supply
DPS-500 140-watt redundant power supply
DPS-800 2-slot redundant power supply chassis
DPS-900 8-slot redundant power supply chassis
