DEM-310GM2EOL EOS
Apraksts
D-Link’s new line of Gigabit Interface Converters (GBICs) and Small Form-Factor Pluggables (SFPs) transceivers represent an industry leading combination of performance and affordability. D-Link’s new Gigabit transceivers are available in two form-factors: standard (GBIC) or (SFP)/mini-GBIC.
The DEM-310GM2 is a high performance 1310nm multimode GBIC transceiver. Supporting full duplex, Gigabit speeds on multimode fiber for distances of up to 2km on 62.5µm or 50µm fiber. The unit features a metal housing to reduce EMI and to increase durability. The DEM-310GM2 is hot pluggable and is backed by a standard 3-year product warranty and free technical support.
Īpašības
Performance
Data Rate Gigabit
1.250Gbps (Bi-Directional)
Data Rate Fiber Channel
1.062Gbps (Bi-Directional)
Optical Receiver Sensitivity
-12dBm (Max)
Transmission Range
- 62.5/125µm:  Up to 2km
- 50.0/125µm:  Up to 2km
Connector Type
SC  Type
IEEE
802.3
Sertifikāti
Informācija pasūtījumam
DEM-310GM2 1000BASE-SX+ Multimode GBIC
