DEM-410X
1-Port 10-Gigabit XFP Module for DGS-3600 Series
Kur iegādāties
Apraksts
The D-Link XFP module provides high-speed 10-Gigabit connection on the secure fiber cable. It provides a single or dual XFP slots and can be slid into an open slot of a D-Link Gigabit switch. A number of 10Gigabit transceivers are available for selection for installation in the XFP slot. Data transfer is operated in the full-duplex mode at 20 Gigabits per second on either the multi-mode or single-mode fiber network cable, depending on the type of transceiver being installed.
The D-Link XFP module allows flexible deployment of 10-Gigabit connection and is ideal for bandwidth-hungry applications that can meet greater cable distances and low signal interference requirements in the Local Area Network, Wide Area Network and Metropolitan Area Network.
Īpašības
Number of XFP Slots
1 XFP slot
Data Rate & Operation
20 Gigabit per second (full-duplex)
Switch Compatibility
DGS-3400 series switches
Transceiver Support
- DEM-421XT (up to 300 m on multi-mode fiber cable)
- DEM-422XT (up to 10 km on single-mode fiber cable)
- DEM-423XT (up to 40 km on single-mode fiber cable)
Fiziskie raksturlielumi
Dimensions
150mm x 57mm x 28mm
Weight
184 grams
Operating Temperature
0  to 40 C
Storage Temperature
-25  to 55 C
Operating Humidity
10% to 90% RH non-condensing
Storage Humidity
5% to 90% RH non-condensing
Emission
- FCC Class A
- CE
- C-Tick
Sertifikāti
Informācija pasūtījumam
DEM-410X  Module
- 1 XFP Slot
- Compatible With DGS-3400 Series Gigabit Switches
Attēli
DEM-410X
Skatiet arī
