DKVM-IP16LCDEOL
16-Port KVM Over IP Switch with VGA, USB Ports and Built-In Console
Apraksts
The D-Link DKVM-IP16LCD 16-port KVM Over IP switch with VGA ports, four USB ports, one 10/100Base-TX port and built-in console allows you to manage up to sixteen computers locally with external console (one monitor, one keyboard and one mouse) or built-in console (LCD, keyboard and touchpad), or remotely through the Internet. This KVM Over IP switch supports hot-plugging - you don't need to turn your computers off before installing the device. The DKVM-IP16LCD allows you to switch between computers quickly and easily using the buttons located above built-in keyboard, keyboard hot keys, OSD menu or Web-based GUI. The DKVM-IP16LCD supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires. Two USB ports can be used for connecting external devices, for example, USB-disk. This KVM Over IP switch can be mounted in a 19-inch rack.
Īpašības
Hardware
Ethernet port
• 10/100Base-TX port
LEDs
• Power
• 16 port LEDs for connected PCs
• Link/Speed (per Ethernet port)
Buttons
• 16 port switching buttons
• Power, Down, Up, Menu, Auto buttons
• Reset button
Enclosure
• Metal, 19-inch rack mountable
Ports for connecting management console
• Monitor (local): VGA
• Keyboard (local): USB Type-A
• Mouse (local): USB Type-A
Ports for connecting KVM cables
• 16 VGA ports
KVM cable connectors for connecting PC
• Video: 15-pin HDB connector (VGA)
• Keyboard/Mouse: USB Type-A connector
Ports for connecting external devices
• 2 USB Type-A ports
Built-in console
• 19-inch LCD with the 1280x1024 resolution
• Keyboard
• Touchpad
General Specifications
Connected PCs
• Up to 16
Autoscan mode
• Yes
Sound notification of switching
• Yes
Remote management via IP address
• Web-based GUI
• VNC
Switching between PCs
• Switching buttons above built-in keyboard
• Hot keys
• OSD menu
• Web-based GUI
Functionality
• Managing several remote servers
• Access to BIOS
• SSL/TLS encryption
• Lack of influence on the performance
• Automatic selection of the optimal video resolution
Max. resolution for local and remote console
• 1920x1440
Physical Parameters
Weight
• 15 kg
Dimensions (L x W x H)
• 570 x 488 x 44 mm
Environmental Conditions
Power Supply
• 12 V DC power adapter
Temperature
• Operating: -50 to 80 °C
• Storage: -20 to 60 °C
Humidity
• 0% to 80% non-condensing
Compatible KVM cables
• DKVM-CU/B
• DKVM-CU3/B
• DKVM-CU5/B
Sertifikāti
Informācija pasūtījumam
DKVM-IP16LCD 16-Port KVM Over IP Switch with VGA, USB Ports and Built-In Console
