DKVM-4KEOL
4-Port PS/2 KVM Switch
Apraksts
The D-Link DKVM-4K 4-port PS/2 KVM switch allows you to manage up to four computers with one monitor, one keyboard and one mouse. The DKVM-4K requires no driver installation and no external power adapter connection. This KVM switch supports hot-plugging - you don't need to turn your computers off before installing the device. The DKVM-4K allows you to switch between computers quickly and easily using the buttons located on the top panel or keyboard hot keys. The DKVM-4K supports autoscan mode, which provides automatic switching to the next PC after the scan interval expires.
Īpašības
B | A | |
Hardware | ||
Ports for connecting KVM cables | • 4 VGA ports |
• 4 VGA ports
• 4 PS/2 ports (keyboard)
• 4 PS/2 ports (mouse)
Ports for connecting management console |
• Monitor (local): VGA
• Keyboard (local): PS/2
• Mouse (local): PS/2
KVM cable connectors for connecting PC |
• Video: 15-pin HDB connector (blue) (VGA)
• Keyboard: 6-pin mini-DIN connector (purple) (PS/2)
• Mouse: 6-pin mini-DIN connector (green) (PS/2)
LEDs | • 4 port LEDs for connected PCs | |
Buttons | • 4 port switching buttons | • 1 port switching button |
Enclosure
• Plastic | |
Connected PCs | • Up to 4 | |
Autoscan mode |
• Yes
Switching between PCs |
• Switching buttons on the top panel
• Hot keys
Sound notification of switching
• Yes | |
Max. resolution | • 2048x1536 | |
Dimensions (L x W x H) | • 100 x 65 x 25 mm | • 178 x 105 x 30,5 mm |
Weight | • 725 g | • 272 g |
Power Supply | • From PS/2 keyboard port on PC (no external power adapter required) | |
Temperature |
• Operating: 0° to 50°C
• Storage: -20° to 60°C
Humidity | • 0% to 80% non-condensing | |
Optional Accessories | ||
KVM Cables* |
• DKVM-CB/1.2M/B
• DKVM-CB/B
• DKVM-CB3/B
• DKVM-CB5/B
• DKVM-CB/A
• DKVM-CB3/A
• DKVM-CB5/A
*Note: KVM Cables of B hardware version are compatible only with the DKVM-4K KVM switch of B hardware version. KVM Cables of A hardware version are compatible only with the DKVM-4K KVM switch of A hardware version.
Sertifikāti
Informācija pasūtījumam
DKVM-4K 4-Port PS/2 KVM Switch
