Apraksts
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card,
and can be used to connect to the Internet, and for fax and voice communication.
