DCS-3430EOL EOS
wireless N day & night Network CAMERA with 3g mobile video support
Apraksts
FULL-FEATURED WIRELESS SURVEILLANCE CAMERA
D-Link DCS-3430 is a versatile day and night wireless network camera, ideal for small-to-medium business applications and remote monitoring capabilities over the Internet. The camera employs a superior CMOS sensor with low lux sensitivity to deliver a truly superior image quality under varied lighting conditions. The DCS-3430 is equipped with 2 digital input ports for sensors or alarms, 1 digital output port for an alarm, 1 power output port for an LED illuminator and a BNC connector which provides both analog and digital interface video transmissions. An RS-485 port is also included for external pan/tilt devices. Additionally, the 12V interface provides power for an optional LED illuminator. A built-in Infrared Cut Removable (ICR) filter in the DCS-3430 allows the camera to capture images in both good light and low light conditions by switching the infrared cut filter. Additional items such as an auto iris lens, IR LED lens or a night vision illuminator can be added to the DCS-3430.  The DCS-3430 can be placed anywhere on the network either through a wired Ethernet or wireless 802.11 b/g/n connection. You can also instantly take snapshots while remotely viewing the video feeds from a Web browser.
VIEW LIVE VIDEO FROM A 3G MOBILE PHONE
A live feed from the camera can be accessed on a 3G mobile network by using a compatible mobile phone or PDA with a 3G video player. Anywhere within the 3GPP service area, users have a flexible and convenient way to remotely monitor a home or office in real time.
REMOVABLE IR CUT FILTER FOR CONTINOUS MONITORING
The IR Cut Filter can be manually applied via web GUI, or set to automatically adjust based on lighting conditions. This feature enables the camera to capture crisp color images during the daytime, and grayscale images in low-light.
TRIPLE CODEC & MULTIPLE PROFILES
To maximize bandwidth efficiency and improve image quality, DCS-3430 provides real-time video compression in MJPEG, MPEG-4 and H.264 formats. Furthermore, the DCS-3430 supports 4 separate profiles simultaneously and is capable of recording in MJPEG, MPEG-4 and H.264 compression with D1/CIF/QCIF resolution for a smooth performance. This kind of versatility enables the use of a wide variety of security applications, whether it’s keeping an eye on your home during lunch through a 3G enabled PDA, managing an organized directory of recorded video files on a network attached storage (NAS) device/SD card, or fine-tuning a security system in real-time over the local network.
Īpašības
CAMERA SPECIFICATIONS
• Built-in 1/4” CMOS sensor
• Built-in IR-cut removable filter
• Minimum illumination: 0.5 lux @ F1.8 (typical); 0 lux (10 meter range with optical IR lens)
• CS mount lens: 6mm, F1.8
• Resolution: 640 x 480
• Electronic Shutter:
• NTSC: 1/60 ~ 1/100,000 sec.
• PAL: 1/50 ~ 1/110,000 sec.
• Lens mount support: Auto-Iris or IR lens (10meter range)
• Field of view: 51° diagonal, 31°vertical, 41° horizontal
LED INDICATORS
• Link & Activity
• Power
RESET BUTTON
• Reset to factory default settings
External device interface
• 2 Inputs:
   + Photo Relay
   + Active High 12V, +/-3V, Dropout: 0 VDC
• 1 Output:
   + Photo Relay
   + Close circuit current: AC 70mA or DC 100mA; 400hm
   + Open circuit voltage: 240VAC or 350VDC
   + Power output: 12V DC 200mA
• RS-485 connector for external PT devices
MEMORY
• SDRAM: 64 MBytes
• Flash Memory: 8 MBytes
VIDEO FEATURES
• Adjustable image size, quality and bit rate
• Time stamp and text overlays
• Motion adaptive de-interlacing
VIDEO RESOLUTION
• NTSC support:
  + up to 30 fps at 176x120
  + up to 30 fps at 352x240
  + up to 30 fps at 704x480
• PAL support:
  + up to 25 fps at 176x144
  + up to 25 fps at 352x288
  + up to 25 fps at 704x576
VIDEO ALGORITHM SUPPORT
• JPEG for still images
• MJPEG/ MPEG4/H.264 multi-profile compression
• Supports up to 4 video profiles simultaneously
• Supports 3GPP mobile surveillance
Digital Zoom
• 16X
Microphone
• Omni-directional
• Frequency 20 to 20,000 Hz
• S/N ratio: over 58dB
AUDIO
• Sampling Rate:
  + GSM-AMR: 12.2Kbps
  + PCM: 8Kbps
• Full duplex audio communication
Network connectivity
• 10/100 Mbps Fast Ethernet Auto-negotiation
• Frequency Range and Channels
  + 2.412-2.4835 GHz
  + 3 Channels (depend on Area)
• Transmit ion: 2TX, 2RX
• Data Rate:
  + IEEE 802.11n: From MCS0 to MCS15
  + IEEE 802.11g: 54, 48, 36, 24, 18, 12, 9, 6 Mbps
  + IEEE 802.11b: 11, 5.5,2, 1 Mbps
  + Auto-select or manual
• Output Power
  + 12 dBm@11n (Typical)
  + 12 dBm@11g (Typical)
  + 16 dBm@11b (Typical)
• Sensitivity
  + 802.11n: Packet Error Rate < 10%, MCS6 < -66 dBm
  + 802.11g: Packet Error Rate < 10%, 54Mbps < -66 dBm
  + 802.11b: Packet Error Rate < 8%, 11Mbps < -82 dBm
• Antenna
  + Connector: MHF
  + Operating Frequency: 2.4Ghz
• Security
  + WEP
  + WPA-PSK
  + WPA2
NETWORK INTERFACE
• IEEE 802.3/802.3u 10/100BASE-TX Ethernet port
• Supports full-duplex operations
• Supports 802.3x Flow Control in full-duplex mode
NETWORK PROTOCOL SUPPORT
• IPv4, ARP, TCP/IP, UDP, RTSP, RTP, RTCP, HTTP, SMTP, FTP, NTP, DNS, DHCP, UPnP, DDNS, PPPoE, Samba Client, 3GPP
REMOTE MANAGEMENT
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive via web browser or to NAS or SD card
SECURITY
• Administrator and user group protected
• Password authentication
D-VIEWCAM SOFTWARE FUNCTIONS
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Management functions are provided in the web interface
• Scheduled, motion triggered, or manual recording options
SYSTEM REQUIREMENTS
• Operating System: Microsoft Windows 2000, XP or Vista
• Browser: Internet Explorer, Firefox, Mozilla or Opera
• 3GPP Mobile Phone
Sertifikāti
Informācija pasūtījumam
DCS-3430  Wireless N day & night Network CAMERA with 3g mobile video support
Attēli
DCS-3430
View from the right
Pārlādēt
Skatiet arī
