DCS-5222LEOL EOS
HD Wireless N Pan & Tilt Network Camera
Kur iegādāties
Apraksts
The DCS-5222L HD Wireless N Pan & Tilt Network Camera is a wireless pan/tilt network camera with megapixel resolution designed for indoor surveillance applications and detailed remote monitoring. The camera is also mydlink™-enabled, which provides user-friendly setup and instant remote viewing through the mydlink website or through the mydlink app for iOS and Android devices.
Full-featured Wireless Surveillance Camera
The DCS-5222L HD Wireless N Pan & Tilt Network Camera is ideal for small and medium business applications which require coverage of a large area, or remote monitoring. It gives you detailed, 24-hour remote surveillance of a large area by using a megapixel high-resolution HD image sensor for high-quality video and a built-in IR illuminator for low-light surveillance. The DCS-5222L can also be connected to your network wirelessly, allowing you to place the camera anywhere that has a Wi-Fi signal, eliminating the need to install additional network cabling.
A Complete Surveillance System
The DCS-5222L includes a built-in CPU, allowing it to function as a complete, standalone surveillance tool. Recordings can be made continuously, whenever movement is detected, or according to a predefined schedule. E-mail notifications can be sent when specific events occur, keeping you informed of what is hapenning, no matter where you are. The built-in microSD slot allows the camera to record independently, or can serve as a backup to continuously record video even if the network connection is lost. The DCS-5222L can also be used as part of a multi-camera surveillance system through the included D-ViewCam software, which supports up to 32 cameras.
Sharp Image Monitoring from Different Angles
With sharp, responsive pan/tilt movement and digital zoom, the HD Wireless N Pan & Tilt Network Camera gives you full control, so you can quickly scan a wide area from a variety of angles, and 4x digital zoom lets you zoom in on specific areas for more detail. The DCS-5222L can also be set to automatically move to specific preset positions, allowing the camera to patrol particular areas of interest within a surveillence area.mydlink-enabled for Simple Setup and Convenient.
Remote Monitoring
D-Link’s convenient mydlink zero-configuration setup gets you up and running in no time – just connect the DCS-5222L to a mydlink-enabled router, and your camera will automatically configure itself and appear in your mydlink account. Once connected, use the mdlink website to give you convenient access to your video feeds from any internet-connected PC. You can even view your camera feeds on your smart phone or tablet with the mydlink iOS and Android apps, so you can keep an eye on things even while on the go.
Īpašības
Camera Specifications
• 1/4” Megapixel Progressive CMOS sensor
• 5 meter IR illumination distance
• Minimum illumination 0 lux with IR LED on
• Built-in Infrared-Cut Removable (ICR) Filter module
•  Focal length 4.57 mm
• Aperture: F1.9
•  Exposure Time: 1/50 ~ 1/15,000
• Angle of view:
  • (H) 45.7°
  • (V) 29.5°
  • (D) 52.9°
• Built-in Microphone
Video Features
• Configurable image size, quality, frame rate, and bit rate
•  Time stamp and text overlays
• Configurable motion detection windows
• Configurable shutter speed, brightness, saturat contrast, mirror, flip
Video Compression
• H.264/MPEG4/MJPEG format simultaneous compression
• H.264/MPEG4 multicast streaming
•  JPEG for still images
Video Resolution
• 16:9 (supports frame rates up to 30 fps)
• 1280 x 720
• 640 x 352
• 320 x 176
• 160 x 80
Pan/Tilt/Zoom
• Pan Range: -170° to 170°
• Tilt Range: -25° to 90°
• Digital Zoom: 4x
• Manual Pan Speed: 1-10
• Manual Tilt Speed: 1-10
• Position Presets: 10 points
Audio Compression
• ADPCM, PCM
Network Protocol Support
• IPv4
• ARP
• TCP
• UDP
• ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• FTP Client
• HTTP Server
• PPPoE
• RTP
• RTSP
• RTCP
• 3GPP
Network Interface
• IEEE 802.11n
• 10/100 BASE-TX Fast Ethernet
External Device Interface
• MicroSD/SDHC Slot
• Audio Output
• DI/DO Port
Remote Management
• Take snapshots/video clips and save to local hard drive via web browser
• Configuration accessible via web browser Security
• Administrator and user group protected
• Password authentication
• HTTP and RTSP digest encryption
Surveillance
• Record video continuously
• Record video according to a weekly schedule
• Record video when motion is detected
• Upload snapshots/video clips via e-mail
• Upload snapshots/video clips via FTP
Mobile App Support
mydlink Lite app for iOS and Android devices
Operating System
Microsoft Windows 8/7/Vista/XP SP3
Compatible Browsers
Microsoft Internet Explorer 6 or higher, Firefox 1.5 or higher, or other Java-enabled browser
Supported Mobile Devices
• Mobile devices with a 3GPP player, such as Packet Video Player 3.0, QuickTime 6.5, or Real Player 10.5
• mydlink™ app requires a mobile device running iOS or Android
Fiziskie raksturlielumi
Dimensions
114 x 114 x 125 mm (4.46 x 4.46 x 4.92 inches)
Weight
540 grams (1.19 lb)
Power Input
Input: 12 V/1.25 A, 50/60 Hz
Temperature
• Operating: 0 to 40 °C (32 to 104 °F)
• Storage: -20 to 70 ºC (-4 to 158 ºF)
Humidity
• Operating: 20% to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• FCC Class B
• C-Tick
• CE LVD
Sertifikāti
Informācija pasūtījumam
Attēli
Skatiet arī
