Ātrā meklēšana
Produkta iespējas:
HD PoE Fixed Network Camera
Apraksts:
The D-Link DCS-3010 is a full-featured entry level HD PoE Fixed Network Camera, equipped with 1/4” Megapixel Progressive Scan CMOS sensor and a 4mm iris lens. The camera can capture HD video at resolutions of up to 1280 x 800 with frame rates up to 30 fps. Snapshots and video can be saved to a network drive, or to onboard (optional) storage with the built-in microSD Card slot.
High Definition Surveillance
The DCS-3010 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera’s video so you can survey a large area easily. A Power over Ethernet (PoE) port allows you to connect the camera to your network and power it through a single cable, simplifying deployment and doing away with the need for a nearby power outlet.
Multiple Video Streams
The DCS-3010 supports simultaneous streaming of H.264, MPEG-4, and MJPEG video to provide both high-quality and bandwidth-efficient compression formats. Additionally, the DCS-3010 supports multicast H.264 and MPEG-4 streaming, allowing users to view the camera feed by subscribing to a multicast IP address on the network.
A Complete, Expandable Surveillance Solution
The DCS-3010 is a self-sufficient surveillance solution, capable of recording snapshots and video to a microSD card without requiring a PC or network storage device.* If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
* microSD card not included.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
