Ātrā meklēšana
Novecojis modelis - noņemts no ražošanas
Produkta iespējas:
Broadband Videophone
Apraksts:
The D-Link DVC-2000 i2eyeTM VideoPhone introduces the world of video conferencing over the Internet, to bring you and your family, friends and colleagues together. Since the DVC- 2000 i2Eye VideoPhone is a stand-alone device, you do not need a computer to video conference over the Internet.
The previously complicated process of conducting a video conference is simplified with the DVC-2000. With the DVC-2000 plugs in a standard Ethernet network cable connected to your broadband Internet connection, you are ready to conduct real-time videoconferencing.
Using advanced video compression technology, the DVC-2000 VideoPhone maximizes the image and audio quality within the available bandwidth. The DVC-2000 can send and receive video at up to a full 30 frames per second. It is an ideal solution for consumers and small businesses with high-speed Internet access.
Easy to use set-up wizards guide you step-by-step through the set-up of the DVC-2000 VideoPhone. You can be up and working in minutes. With the DVC- 2000 it is easy to make changes to personalize your videoconferencing display.
DVC-2000 video phone comes with its own built-in screen. The entire product operates as a completely video phone. It features audio/video out connections so that you can connect it to a TV if you want.
Be there real-time, anytime. You won’t miss a moment with your friends, family and colleagues with the i2eye DVC- 2000 VideoPhone.
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu
