Ātrā meklēšana
Produkta iespējas:
High Speed Dome Network Camera with 30X optical Zoom
Īpašības:
Camera Hardware Profile
• Sony Super HAD-II 1/4” CCD sensor
• Minimum illumination 0.1 lux (Color); 0.01 lux (B/W)
• Optical Zoom: 30X
• Focal length: 3.4 to 102 mm
• Angle of View (Horizontal): 2.2° to 60.8°
• 650 TVL
• Built-in Infrared-Cut Removable (ICR) Filter module
• S/N ratio > 50 dB (AGC off)
• Electronic shutter 1/1 to 1/10K sec.
• 1-12x variable digital zoom
PTZ Hardware Profile
• Pan travel: 360° endless
• Tilt Travel: -10° to 190°
• Manual Speed: 0.5° to 90°/s
• Presets: 256 points
• Preset Accuracy: 0.225°
• Preset Speed: 5° to 400°/s
• Sequence Paths: 8
• Auto Pan Paths: 4
• Cruise Paths: 8
• Pan and tilt speed proportional to zoom ratio
• Resume after Power loss
• Home Function: Preset, Sequence, Auto pan, Cruise
• Auto Flip: Mechanical/Digital/Off
• Digital Slow Shutter
• Image Freeze
• Image Inverse
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Configurable motion detection windows
• 16 configurable privacy mask
• Configurable white balance, shutter speed, brightness, saturation, contrast, sharpness
Video Compression
• Simultaneous H.264/MPEG4/MJPEG format compression
• JPEG for still images
Video Resolution
NTSC Support:
• Up to 30 fps at 176 x 120
• Up to 30 fps at 352 x 240
• Up to 30 fps at 720 x 480
PAL Support:
• Up to 25 fps at 176 x 144
• Up to 25 fps at 352 x 288
• Up to 25 fps at 720 x 576
Audio Support
• 2-way audio support with G.726 compression
External Device Interfaces
• 10/100 BASE-TX Ethernet port
• 8 Alarm inputs
• 1 Alarm output
• Audio input / output
• Video output
Network Protocols
• IPv4
• TCP/IP
• UDP
• ICMP
• DHCP Client
• NTP Client (D-Link)
• DNS Client
• DDNS Client (D-Link)
• SMTP Client
• FTP Client
• HTTP / HTTPS
• Samba Client
• PPPoE
• UPnP Port Forwarding
• RTP / RTSP/ RTCP
• IP filtering
• 3GPP
• IGMP
• ONVIF Compliant
Security
• Administrator and user group protection
• Password authentication
System Requirements for Web Interface
• Operating system: Microsoft windows, 2000, XP, Vista, 7
• Browser: Internet explorer, Firefox, Netscape, Opera
Event Management
• Motion detection
• Multiple event notification
• Event notification and upload snapshots/video clips via HTTP, SMTP or FTP
• Supports multiple HTTP, SMTP and FTP servers
• Multiple recording methods for easy backup
Remote Management
• Configuration accessible via web browser
• Take snapshots/video clips and save to local hard drive or NAS via web browser
Mobile Support
• Windows 2000 / XP / Vista / Win 7 / Pocket PC / Mobile Phone which 3GPP
D-ViewCam System Requirements
• Operating System: Microsoft Windows 7 / Vista / XP
• Web Browser: Internet Explorer 6 or higher
• Protocol: Standard TCP/IP
D-ViewCam Software Functions
• Remote management/control of up to 32 cameras
• Viewing of up to 32 cameras on one screen
• Supports all management functions provided in web interface
• Scheduled motion triggered, or manual recording options
Physical Parameters
Power Input
• AC 24 V / 3 A
Max. Power Consumption
• Max 65 W (with heater)
Dimensions
• Height: 302.5 mm
• Diameter: 190 mm
Weight
• 2.6 kg
Temperature
• Operating: -40° to 50°C
• Storage: -20° to 70°C
Humidity
• Operating: 20% to 80% (Non-condensing)
Certifications
• CE (Class A)
• CE LVD (EN60965-1)
• FCC (Class A)
• ICES-003
• C-Tick
Fiziskie raksturlielumi
Produkti un risinājumi | Atbalsts  | Jaunumi  | Par uzņēmumu |
